Question about Refrigerators
Srd25 amana side
Thermostat
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: does defrost not working on
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 16, 2011
Hi there i have a client with an amana frigde sxd524ve fault is very ic ed up evap unit no fan running i defrosted unit and resarted system fan now running i believe defrost element and or timer may be...
Okay, rookie ;)
Amana fridges have problem with the defrost thermostat, which you may not notice without looking at the thermostat very closely. If the plastic cover on the thermostat is swollen or is higher on one side - replace the thermostat. Fan in these fridges is connected in series with the heater and the defrost thermostat.
... And finally 127 Ohms for a 110v heating element is too high, resistance must be lower. If you measure it through the defrost thermostat - separate them and check again.
Oct 14, 2009 | Amana SXD524VW Side by Side Refrigerator
The fan does not work
If this is an Amana, the evaperator fan motor works through the defrost thermostat. If the thermostat is open (no continuity), the fan motor will not run. This is usually the solution for this particular brand. Replace the thermostat and once it satisfies (within 5-10 mins. of replacement), the fan should start to run.
Jul 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Stuck in defrost mode after changing timer and thermostat
Amana adaptive defrost:
Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 05, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Restart after year; light goes on nothing happens - no compressor
If doors were close during the time of not using the refrigerator, I believe the thermostat has become stuck. Straight wire the two wires on back of thermostat to see if compressor starts. Unplug first. Let me know, Sea Breeze
Mar 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana side by side
your thermostat in the frig is bad,you need to pull it and checkit with an omhs meter,let me know what you find-mike
Oct 15, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
