Unable to clean 32 brother mfc-j220
Always error....no jammed paper..
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
SOURCE: Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Posted on Jul 19, 2009
  • 265 Answers
SOURCE: paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Posted on Dec 12, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
The machine always detect a paper jam without a paper?
Is there a small piece of paper over the paper jam sensor?
Feb 01, 2015 | Office Equipment & Supplies
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
HP p2015dn I can't find error 13.000 in the manual
13.XX error msg almost always refers to a paper jam. Paper jam can be an actual paper jam, can be a sensor that is broke or stuck in the wrong position, Could also be a false paper jam. Printer tries to feed paper, paper never feeds, causing the paper path sensor to say "hey, that sheet of paper never reached me, so it must have jammed somewhere. Check the paper path for a paper or piece of paper.
Jul 21, 2011 | Office Equipment & Supplies
Our shop's Canon ImageRunner 3025 shows a jammed paper error, but there is not jammed paper in the copier that I can see. So what else could be triggering this jammed paper error? Thanks, Seth
You need not to pannic.Those paper jams are always there... What you need to do is to check you paper arrangement in papers tray sometime rough arrange may led to paper jams everytime
Thanks
Omari Saburi
Mar 04, 2011 | Canon ImageRunner 3025 Black and White...
Paper jam problem
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
Jul 20, 2010 | Canon imageRUNNER 1370F Grayscale Copier
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
Paper Jam
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 30, 2009 | Canon PIXMA MX300 All-in-One Printer
Persistent paper jam error
How old is your model? This could be dirty rollers. See how I fixed that problem on this site: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if this helped. OK?
May 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Jun 12, 2008 | HP LaserJet 2420 Printer
Paper jam error
your software doesn't have problems... its your printer itself or the way you put on the paper that's why its always having error....
Feb 14, 2008 | Epson Stylus Photo R300 InkJet Printer
jasbo
jasbo
