Question about Tablets & eReaders
Mitsubishi da -r15 receiver
Was just wondering the spec's on the da-r15
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
How do I remove the HDD from a Toshiba r15 s822 laptop
Hi!
You can click this link to download the manual for your Toshiba r15 s822. Please click here Toshiba r15 s822.
Jul 20, 2011 | Toshiba Satellite R15-S822 Tablet PC
I need a driver for my toshiba satelite r15s829 i'm not really sure what driver i need but in device manager it says i'm missing a video controller.
Here is a link to the Toshiba support web site for the Satellite R15-S822.
Specify the operating system to refine the search or look for the driver in the list.
If you have the recovery CD you can also use it.
May 29, 2011 | Toshiba Satellite R15-S822 Tablet PC
Reloaded my toshiba r15-2822 cant find 3
Ok you made a mistake, there is no r15-2822, it should be r15-s822. The driver page is here http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=882875&rpn=PSR10U&modelFilter=R15-S822&selCategory=3&selFamily=1073768663. If you have trouble finding the drivers for your OS, you can always use another os driver but is not recommended.
Download this program. Unknown Devices (UKD) This program is very good at Identifying the device. Just right click the listing and click search web then remove everything in the search except the device ID and this will tell you exactly what the Unknown Device is.
May 19, 2010 | Toshiba Satellite R15-S822 Tablet PC
My Satellite R15 S829 recovery disk was lost
You can call (800) 457-7777 and get a new set. I see Toshiba has bumped the shipping and handling to $24.95 standard, $29.95 next day. Have your serial number and a credit card handy.
Jun 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Replace fan on Satellite R15-S829
MAKE SURE YOU HAVE REMOVED THE TWO SCREWS UNDER THE COVERS AND THE ONE VISIBLE AFTER REMOVING THE DVD.
Apr 03, 2009 | Toshiba Satellite R15-S822 Tablet PC
Toshiba satellite R15 touchscreen driver
Hi , if you have WIn XP or XP SP2 click on the link below to download the touch pad drivers for Satellite R15-S822.
If you are using Vista then you will have to Manually selct Wondows Vista from the drop down box on the page.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=872584&moid=882875&rpn=PSR10U&BV_SessionID=@@@@1278931486.1212681927@@@@&BV_EngineID=ccchadeefjhhhdecgfkceghdgngdgmm.0&ct=DL&all_docs=false
Dec 02, 2007 | Toshiba Satellite R15-S822 Tablet PC
Tablets & eReaders Logo
62 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
