Question about Honeywell 527SHON103BLK 12-Watt Gable Mount Solar Power Attic Fan
Replacement solar panels
I want to purchase new solar panels for my fans. I have (4) and my panels were damaged.
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Partial showing on screen of numbers -- 4 shows up without upper front piece. 3/4 shows 0.15 instead of 0.75. Any ideas for how to reset screen characters?
replace the battery if this dose not solve the problem then the calculator is damaged and needs to be repaired. i however do not believe that the parts can be purchased
Mar 05, 2011 | Texas Instruments TI-25X Solar Calculator
Outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
I purchased hampton bay 4 pack solar led landscape lights 237 002 - 2 lights work, 2 don't, I put in new batteries but still can't get them to work - they have been outside for a month. They worked last...
Sun burns out the photocell in lights. Hampton Bay uses cheap components in their Fans and Lighting all made in China for a fraction of what you paid. Dont waste time calling gpwarranty.com they dont care.
Best option..buy a good set and dont buy them from Home Depot, Hampton Bays primary retailer, sort of voting with your wallet.
Sep 23, 2009 | Hampton Bay 24002 Ceiling Fan
Swimming pool solar heater panels freeze problem
Depending on the manufacturer, your solar panels may be replaced under warranty. Our installer says that once the panels begin leaking, they tend to deteriorate fairly rapidly. For example, three leaks the first year, 7 leaks the second year, 30 leaks the third year.
Many solar panels are warrantied against freezing, but that is not likely to be the future of the warranties, because they inevitably DO freeze and leak.
If there are just a few leaks, it is easier to fix them - a Fafco Solar panel repair kit can usually be bought from your installer for about $25.00.
If you turned the pump on to manual to circulate the water through the panels, that should prevent a freeze - but will cost you the electrical cost to run the pump.
Our experience has been that it is better NOT to drain the panels - we had many fewer leaks the years we have not drained the panels, despite occasional hard freezes in our part of California.
In addition, your rooftop installation should help radiate some heat up to the panels to keep them from freezing.
Check your warranty and get the panels replaced if there are more than a few leaks.
Mar 21, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Honeywell 527SHON103BLK 12-Watt Gable Mount Solar Power Attic Fan Logo
121 people viewed this question
Top Honeywell Renewable Energy Experts
Marco De La Fuente...
Brian Lee
Kelly C
Kelly C
Level 1 Expert
Are you a Honeywell Renewable Energy Expert? Answer questions, earn points and help others
