Question about Furniture
Bow can i remove the tiles from the walls
I wanna put new tiles on my kitchen how can I removed the old ones
  • 8 Answers
SOURCE: How to Remove an OTR Microwave from the wall
first you need to take the grill off the front of the micro there should be two screws on the very top of the unit that allow you to take the grill cover off there also should be two screws in the cabinet above the micro that hold the unit in place some models have a silver hook or latch on the left side that you pull forward to release the unit from the back plate do not pull on this till you have taken out the two set screw on top of the cabinet after doing this the micro should come down
Posted on Mar 22, 2008
SOURCE: How do I remove old printhead and install a new one?
When you get the cartridge,s out of the tray. Look at the tray and locate where your finger is on the bull eye.. Right above the sticker there you will find a small tab under the top ledge you need to press the tab upwards and the tray will come out.... replacement is to reverse process
Posted on Mar 15, 2009
  • 297 Answers
SOURCE: kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Posted on Jul 24, 2009
  • 6 Answers
SOURCE: can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Posted on Oct 03, 2009
c17hydro
  • 2984 Answers
SOURCE: need to remove ignition switch
Removal & Installation
NOTE This is an extremely difficult and lengthy procedure. You must remove the steering column from the vehicle and disassemble major portions of it. Because the column is collapsible in an accident, it is necessary that it be handled with care to avoid distortion of major parts. It must not be dropped, hammered on or even leaned on, or vitally important parts may deform. The procedure for replacing the ignition switch on tilt type columns is not included here because it involves substantial additional work and the use of several expensive special tools. Unless you are rather experienced, we recommend that the job be left to a competent professional mechanic.
  1. Disconnect the negative battery cable. Remove the clamp bolt from the steering coupling at the lower end of the steering column shaft (located near the steering box, under the hood).
  2. Disconnect the shift linkage from the shift tube lever at the lower end of the column.
  3. Remove the steering wheel with a puller, as described above.
  4. Remove the left sound insulator and lower column cover.
  5. Remove the trim cap or lower trim panel from the instrument panel, depending on equipment.
  6. Remove the steering column cover and toe-pan attaching screws. Remove the shift indicator needle from the shift bowl.
  7. Securely support the column in position and remove the two nuts attaching the column to the underside of the instrument panel.
  8. Lower the column carefully, being careful to retain any spacers that may have been used in order. Disconnect the wiring. Then, carefully remove the column from the inside of the vehicle.
  9. Begin disassembling the column, removing the lock plate, canceling cam, and turn signal switch. See the "Turn Signal" Removal & Installation procedure above.
  10. Remove the ignition lock and key warning switch as described below.
  11. Remove the spring and bolt assembly, and the associated thrust washer. Then, remove the rack preload spring, switch rack, and actuator assembly.
  12. Remove the upper shift lever spring. Then, remove the gear shift lever bowl.
  13. Remove the shift bowl shroud and bowl lower bearing.
  14. Unhook and remove the dimmer switch actuating rod. Remove the attaching nut and remove the dimmer switch.
  15. Remove the attaching screw and stud and remove the ignition switch, disassembling the actuating rod from the hole in the sliding actuator.
Replacing the ignition switch
To install:
  1. Move the ignition switch sliding actuator all the way to the left (ACC) position. Then, move it two detents (OFF-UNLOCK) position to the right.
  2. Then, position the actuating rod hole in the sliding actuator, and install the ignition switch, stud, and mounting screw.
  3. Install the dimmer switch with its attaching nut tightened only loosely. Then, depress the switch slightly until you can insert a 3/32 in. drill through the hole in the switch housing and slider. Force the switch upward to remove any lash and tighten the mounting screw with the switch in this position.
  4. Put the shifter in NEUTRAL and install the shift lever.
  5. Install the shift bowl shroud and bowl lower bearing.
  6. Install the rack preload spring, switch rack, and actuator assembly. Install the spring and bolt assembly, and the associated thrust washer.
  7. Install the ignition lock and key warning switch as described below.
  8. Reinstall the column into the vehicle. Make sure when assembling the lower and upper dash covers that they can slide on the column. If the bracket which mounts the column to the dash has been removed, install the bolts in this order:
    • Left rear
    • Left front
    • Right front
    • Right rear
Tighten the bolts just snug to avoid distorting the column.
  1. Install the switch connector to the ignition switch. Then, position the column in the body and support it there. Install the lockwashers and nuts for the coupling and tighten them. Then, loosely assemble the nuts fastening the mounting bracket for the column to the lower side of the instrument panel.
  2. Position the lower cover to the firewall and ensure that the cover is lined up by starting the left lower screw. Then, install and tighten the right lower screw. Then, tighten the left lower screw. Finally, install and tighten the two screws that fit into the top of the cover.
  3. Tighten first the screw for the left side of the cover clamp; then tighten the screw for the right side of the cover clamp. Finally, install and tighten the remaining cover screws.
  4. Finally, tighten the nuts fastening the column to the underside of the dash. Reinstall the bolt for the steering coupling clamp.
  5. Install the lock plate, canceling cam, and turn signal switch. See the "Turn Signal" Removal & Installation procedure in this section.
  6. Connect the wiring.
  7. Securely support the column in position and install the two nuts attaching the column to the underside of the instrument panel.
  8. Install the shift indicator needle from the shift bowl. Install the steering column cover and toe-pan attaching screws.
  9. Install the trim cap or lower trim panel to the instrument panel, depending on equipment.
  10. Install the left sound insulator and lower column cover.
  11. Install the steering wheel, as described above.
  12. Connect the shift linkage to the shift tube lever at the lower end of the column.
  13. Install the clamp bolt to the steering coupling at the lower end of the steering column shaft (located near the steering box, under the hood).
  14. Connect the negative battery cable and check all column operations for free movement and smooth operation.
Posted on Feb 15, 2010
Cuts are bowed
I heard that the rod that it rides on, may be bent. This is the rod, that you normally adjust, to get your straight cut, parallel to the blade. One mans solution was to turn the rods, so the bend of the rod, was vertical, rather than horizontal. You may want to look into ordering new , hopefully straight rods, from QEP too.
Jul 13, 2013 | Qep Tile Tools 83200 24inch Bridge Saw
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
Show me how to install a part for my frigidaire stove top the switch has change
Sharon,
Pull out stove from the wall,
Unplug stove. Now you are safe!
With a phillips screwdriver, remove the backpanel.
The switch you are replacing, remove knob.
Remove the two screws that hold the switch in place.
When switch is free, remove one wire at a time, and make sure you put them on the new switch as you remove from old.
Fasten switch in place, close up the machine. plug it in
Enjoy your new buner
bweazer
Oct 16, 2010 | Frigidaire FEF366 Electric Kitchen Range
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
I would like remove old vinyl shower wall and install a tile wall. but do i have to remove the drywall also? I'm keeping the shower base.
if the sheetrock is in good shape you should not have any problems. If you are worried about mold and mildew, you might want to change out the drywall with either green coat or yellow coat- these are mold and mildew resistant
Nov 04, 2009 | Home
HOW TO REPLACE SPARK MODULE ON KITCHEN AIDE KDDT207AWH0
It's very simple to replace. Pull the stove away from the wall so you can access the back components.
UNPLUG THE STOVE FROM THE WALL OUTLET.
The spark module is located on that surface below the stove top. Carefully note the position of the old module and label the wires so you can put them in the new module correctly. There should be 2 or 3 screws that are holding the old igniter module in place. Remove the screws, install the new module EXACTLY as the old one had been, and connect your wires. DONE.
Oct 08, 2009 | Kitchen Ranges
Furniture Logo
91 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
