Question about Furniture
How to takes tiles from the wall - Furniture
If I have an area that is 22 x 14.5", how many boxes of 12 x12 tile do I need?
You should allow about 5% for waste that would take you to about 335 . I am assuming the sizes you gave were in feet and inches. Divide the 335 by the number of sheets in a box and take it up to the next full box.
Feb 16, 2015 | Instant Mosaic Metal Tile: 12 in. x 12 in....
How do I take off wall tiles in a bathroom
Safety glasses and a hammer or sledgehammer. If you want to save them, dig out the grout around them and then use a crowbar of sorts to get behind the tile to pop them free
Feb 14, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
I installed bellavita glass tile 8x16 im having issues with mortar stickig to it and holding it on wall.. why?
Your not troweling enough glass thinset onto the wall. The thinset should be creamy and troweled evenly most people hold the trowel to flat or use to small of a trowel you also could lightly coat the back do the tile to give it a good mechanical bond
Mar 23, 2014 | Bellavita Tile Glass Tile - Bellavita...
Bathroom Wall and tiles
As per my view, before applying anything to your bathroom walls, you should take some advices and tips from a professional as they have the proper idea about such quires.
Jul 14, 2012 | Home
We are staying in a rented home with a spa bath. Attached to the spa bath is a hand held shower. The showerhead rests above the bath but the pipe coils somewhere between the tiles and the bath and can be...
The grout between tiles is just for filling the gaps. The tiles are glued to the wall, usually with "thin-set" mortar. Unless that mortar is in very poor condition it is unlikely that you would be able to remove that single tile without breaking it. The wall behind the tile might be water-resistant drywall (a poor quality situation) or it should be cement-board. I suppose it's possible that there is already a hole in the wall behind the tile, but the hole would be smaller than the tile, and assuming 4 inch (not large) tiles, this is a poor choice to gain access to the pipes. The usual access is through the wall from the other side. During initial construction, a removable access panel is sometimes provided (depending on local building codes and whims of the builder). If there is no access panel, and the other side of the wall is drywall, then cutting a generous hole, and fashioning a plywood panel (with trim around the edge to cover the gap between the drywall and the plywood) is a pretty standard and simple approach (depending on your skills). As an alternative and for more info, here's a link describing how to install a plastic snap-in access panel. Good luck! http://www.diylife.com/2008/06/23/plumbing-access-panel-installation/
Jun 01, 2011 | Home
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
Installed the rough in for the Sirus two handle wall mount faucet as per instructions. But the water value is too long and the sprout doesn't go back to the wall. Values are at the indicated lines through...
recalculate the distance, taking into account of drywall, tiles.
if you follow the instruction and the valves are at the indicated line, then you should be OK.
take a piece of scrap drywall and a piece of tile lay it next to the rough in just the way you would have when it is all finish. if it is till too far out, then you have to push the pipe backing back to adjust the distance.
hope that helps
Mar 10, 2009 | Danze D301644BN - 2 Handle Wall Mount...
How do i fit an electric shower to a tiled wall
You may be access the pipes from the other side of the wall containing those pipes. so rather than have to cut into your tiled wall, you will be cutting into whatever is on the other side of that stud wall.
Feb 17, 2009 | Home
Furniture Logo
79 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
