Question about Midea MDF1-30AEN3-BA4 WP 30PT ES Dehumidifier
Where can I get a water drain tube?
Missing water drain tube
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
The water will not drain into the storage tank, and insists on leaking out the back. How can I get it to drain into the tank?
The drain tube and or hole that is supposed to drain water into the bucket is clogged. To solve this problem, do the following:
First, turn the Unit OFF & Unplug it.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. NOTE: if you don't have a Zip Tie, you may use something similar, but NO wire coat hangers.
Hope this helps you and thanks for using FixYa.
Jul 25, 2011 | DeLonghi DD50P Dehumidifier
Unit runs but does not collect water. If I shake unit water will drain into bucket from coil. I pushed a plastic trigger sprayer pickup tube into drain tube and some water came out. I felt some kind of...
Use an 18" long plastic Zip Tie that will fit into the drain tube and carefully slide it in. The tricky part will be when you reach the curve in the drain tube. So be careful, but persistent. Once it has gone as far as it can, slowly pull it out while rotating it. This will help to dislodge the clog. Be prepared for water to follow. This should solve your problem.
Mar 29, 2011 | Haier DM30EAL Dehumidifier
Our unit is hooked up to a hose drain had has been
proably trash in your diverter (the thing that allows water to run to tank, or hose) try a pipe cleaner or blow with air, is it electronically controlled? or is there a valve?
Apr 03, 2010 | Dehumidifiers
Tubing to drain the water into the container for the Amcor TC 120
take a sample piece of tubing to a home improvement,hardware,or appliance parts store to match it up.
Sep 29, 2009 | Dehumidifiers
I have a GE Dehumidifier, Model # AHK40LKG1, Serial # AM166016. Thus far we have used the bucket to empty it. We now want to use the hose attachment to empty it. I find that I have the clear plastic tube...
I have same problem (ie, missing this drain nozzle). From my searching, the GE part number is : WK09X10006.
Found it on : http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
searching for 'drain nozzle'.
My searching (so far) is finding a couple places online to purchase this, but at $14-$15. Still looking for a better (ie, cheaper!) option.
Hope this helps.
Jul 25, 2008 | GE AHG40LJ Dehumidifier
Owners manual missing - my problem
you should have a drain hose connector. this connecter is inserted into the back of the dehumidifier. your hose can then be connected to the connecter. if you are also miising your connecter,sears or any store similiar will have one
Jul 18, 2008 | LG DH404E Dehumidifier
LG Dehumidfier
When you install the drain tube, be sure that it is placed into the drain hole in the dehumidifier. You then will be able to "latch" the tube at the hose end by lowering onto the outer hole opening. This maintains a tight connection and the water will drain properly.
Jun 17, 2008 | LG LD65EL Dehumidifier
Midea MDF1-30AEN3-BA4 WP 30PT ES Dehumidifier Logo
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
Andrew Taylor
Andrew Taylor
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
