Question about Toys
Bobcat 963 starts, run, arms and bucket move, but unit will not go forward or backward
4 Suggested Answers
  • 520 Answers
SOURCE: I have a bobcat 773T
the screeching sound could be a belt slipping. there should be a neutral adjusment on the valves that the sticks are attached to. its just a matter of finding true neutral.
Posted on Jan 16, 2011
SOURCE: BOBCAT 763 LOCKUP WHEN DRIVING, NOW IT WON'T
you may have a altnator charging to much and spiking the computer
Posted on Feb 28, 2011
  • 32 Answers
SOURCE: 773n bobcat will move forward and back but wont raise bucket
Bics coil on control valve not unlocking. Broken wire, bad connection or bad coil
Posted on Nov 16, 2012
My Bobcat 742 Loader will move forward and reverse but the bucket will not raise or tilt.
You more than likely have issues with the hydralic system portion that supports the boom and bucket
Jan 21, 2015 | Toys
Bobcat 753 arms wont move up or down.lights flashing on bix box for valve .have replaced valve on the right side below seat but same problem no movement in arms could it be the sensor switch on the s
if safety bar sw was defective then unit wont move fwd or backwrd . and park brk would not disengauge , no sounds as if you got a defective block pressure sensor for arms ckt
bobcat dealer service should have code scanner for this, would be faster less expensive than just changing parts to find cause
Oct 02, 2014 | Bobcat 773
My bobcat 743 drifts forward and bucket drifts back down,could this be slow leak noted in rear of cyclinder arm connection or other problem?
It maybe a adjustment that is incorrect on the valve bank the leak on the cylinder must be repaired soon can be connected with the bucket that is drifting down the drifting foward can also be a valve that is passing by
Aug 14, 2014 | Garden
Sep 25, 2012 | Bruder Cat Skid Steer Loader
Goes forward just fine and then starts going backwards.
Make sure your spray arms are both pointed in the proper direction to assure forward movement. It will run backward if the spray arms are pointed in the wrong direction.
Thanks for letting me answer your question this evening ...
Jun 05, 2011 | John Deere Gilmour Traveling Sprinkler -...
I have a bobcat 773T with the Kubota engine. It is a 2001 model. All of a sudden when I move the machine forward or backward it continues going forward or backward slowly and sometimes it will either turn...
Jan 16, 2011 | Toys
My zenith zd309 light keeps blinking but the water
If the unit is titled forward at all, the "full bucket" "trip switch" will not trigger off as it should. Be sure the unit is on a flat, level surface, or leaning backward slightly--this also aids drainage through the drain tube, if that's your set-up.
Jun 07, 2010 | Dehumidifiers
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Toys Logo
52 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
