Question about Ovens
I have a white Westinghouse wall oven model wbe5b1-the top panel where the clock is won't light up. Is there a fuse that could be blown and if so where is it located?
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
SOURCE: westinghouse silhouette electric wall oven and
how to remove the door
Posted on Sep 06, 2009
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
  • 34 Answers
SOURCE: I have frigidaire slide-in stove
Most likely it's the clock/timer board that has to be replaced.
Posted on Nov 26, 2010
Testimonial: "thanks. Can I replace it myself??"
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Westinghouse oven pof668 in auto mode - how do I get it out of auto mode (am renting this property). Oven and grill are not working as power was off until recently
Most models won't work when on Auto. Generally there are push buttons under the clock and one has a picture of a hand (Like a cop holding up his hand to say "Stop"). Press this button and it should go back to manual mode and allow you to use the oven.
What I have said so far is pretty much a guess, based upon experience. I'm also guessing that you don't have a manual to refer to either. However, w
hile I can't find the specific manual for your model, there is a westinghouse oven manual here:
http://manuals.appliancesonline.com.au/westinghouse-dualfuel-ovens/westinghouse_duelfuel_ovens_manual.pdf
and I would bet that the clock setting instructions on page 18 are exactly the same for your appliance!
Jul 28, 2011 | Ovens
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
The center clock-oven module no longer lights up and the oven doesn't work, but the burners on top work. model rf341bxk. The oven light still works. Is there a fuse blown that I can replace?
Hello, welcome to fixya.
Unfortunately many modern ranges do not incorporate fuses into the control panels, other than the 15amp outlets used for plugging in external devices, they are typically the resettable type fuse.
Many manufactures have gone away from the typically glass fuse style circuit interrupters of previous ranges of say 15-20yrs ago and older.
If the clock display is not illuminated nor functioning, but the surface element functions appear fine, it is likely a fault within the clock ( also referred to as a timer or erc ) itself. Check for possible burnt or loose wires going into the timer such as L1 or L2 etc.
**Please unplug the range or turn off the 40amp breaker at your homes service panel before attempting any service to the range**
The part for the timer/clock is # 3196967 and retails for between $167 to $233 at "searspartsdirect.com" and "repairclinic.com" respectively as I type this on June 6/2010.
Hope this info was helpful to you...even if it isn't great news. Please take a moment and rate the info I provided and thanks for visiting "fixya".
macmarkus :)
Jun 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Instruction manual for Westinghouse wall oven
Jun 22, 2009 | Ovens
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
