Question about AcerView 54E 15" CRT Monitor
Colour dissortion Recently i've been having the prob of dark display with my monitor,but thx someone really helped me.. nw the prob is that often when i switch on my pc i lose my red colour and my screen goes blur.. but after sometimes it goes alright.. when im really fed up i usually punch the monitor on top and i find that my true colour appears again.. why is this so?? somebody please help me..
    Problem Solver:
  • 16 Answers
Just open the monitor cover from back. just look for dry soldered transistor on the the yoke of the monitor. theree are three transistors for red blue and green. change both of them and your prob is solved. just again mail me further before attempting so. i will guiode u because it is so dangeros.
Posted on Aug 29, 2007
    Sergeant:
  • 279 Answers
Usually, this is due to a bad connection on one or more of the wires in the monitor data cable. Either the pins aren't making a good connection to the port on your computer, or there's a short in the cable somewhere. If hitting the monitor solves it, it's probably a bad connection between the cable and the monitor, where the wires are soldered into place. If this is the case, I would suggest against trying to repair it. CRT monitors store large amounts of electricity, and a discharge while you are working on it can be deadly. Never open up a monitor case. Try wiggling the connection on the back of the computer next time and see if that fixes it. If it does, remove the cable and check for any loose pins, or bent pins. If there are any, the cable could be repaired, though 15" CRT monitors are so cheap you're probably better off replacing it. Look on craigslist.org for your city. If it has a cite for your city, it's likely you can get a cheap used monitor there.
Posted on Aug 28, 2007
SOURCE:
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
[email protected] I have a Syncmaster 225 BW that became intermittent and finally just went gray and flashed between "analog" and "digital". I them borrowed a Syncmaster 920...
When you tried the replacement monitor, did you have the pc turned off when you connected it, if not then restart the pc and it may work. I realise you probably already have but I don't have that info.
Anyway try both monitors with a computer that is known to work properly (make sure it's off when you plug them in), if both monitors don't work then it's a monitor prob, if one does and the other doesn't then you know one monitor isn't working and if you still can't get the other one to work with your pc then it would suggest that you also have a video problem.
Sounds like the original monitor may have a prob with the inverter or control board, it may even be some bad caps or even a switch (unlikely but possible), but it could be explained by a video problem. So narrowing down where the problem is, is the first step.
Hope this helps you out. Once you've found out where the problem is, you could post back and see if someone on here can help you fix it.
Here's a link, in case you find out it is monitor related, it would help with all the possibilities I mentioned.
http://www.badcaps.net/forum/ - you'll want the section on troubleshooting computer displays
Feb 16, 2011 | Samsung Computers & Internet
Hi there i am having a HUGE problem with my hp pavilion F1503 and was wondering if i could get some help...This monitor is for some odd reason not submitting colours, there is a colour imbalance...at one...
Components assembled in China are rated for 1000 Hrs. and 85C. Using a Fluke 16 or other Capacitor tester; you will find that the Video Controller has blown SMD Caps. You can get these passive components at Digikey.com. Be very careful when soldering these in. This will solve your problem. I also drill several additional holes in the heat shield and back cover to help dissipate heat from the inverter board. If you are not technically savy in component testing I would recommend purchasing a different model /monitor.
Sep 24, 2010 | HP Pavilion F1703 17" LCD Monitor
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
LCD monitor not working
I had to sit in a total dark room so i could make out the writing in the options, went to colour settings there`s three sliders (R) for red (G) for green and(B) for blue all 3 had been put to minus, i returned them to half way and that was it, simple but annoying.P.S good site.
Nov 23, 2008 | Cameras
SCREEN GOES DARK TWO SECONDS AFTER ITS SWITCHED ON
when it goes dark disconnect the data cable of the monitor from the system end and if u still see nothing
monitor bad and if u see the colour scheme monitor working system is the culprit
Oct 04, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
LG 77m monitor
Is the problem on all signal to display? If any signal is dark, the inverter is going bad.
Mar 28, 2007 | LG Studioworks 77M Monitor
NW-E003F mp3 palyer
thats probs cos of copy right or if its downloaded
Nov 24, 2006 | Sony NW-E507 MP3 Player
Colors not distinguishable
Is your monitor by any chance sitting next to unshielded speakers or anything else which could generate an electomagnetic field? You can get some terrific colour shifts with these items. If you do have anything like this put some distance between them and the monitor. Also the auto degauss coil circuitry could be faulty in the monitor. Take it to a repair shop and ask the tech to degauss the tube and see what difference it makes. If it fixes the problem get him to check the degauss system. Don't try this yourself. There's lots of voltage running around inside a TV. Fix don't Fry BMW
Jul 01, 2006 | LG Studioworks 45 14" CRT Monitor
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Open Questions:
\Q;- RICOH PRINTER customer service phone {+1'8OO-8O3^1O69} NuMber USA .ANITA This RICOH PRINTER USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 RICOH PRINTER USA customer tried our tools and information and gave us feedback after they called. The reason customer call [+I8OO-8O3-1069] is to reach the RICOH PRINTER USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, RICOH PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. RICOH PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact RICOH PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling RICOH PRINTER USA Calling RICOH PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from RICOH PRINTER USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with RICOH PRINTER USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare RICOH PRINTER USA's phone numbers against each other. Contacting RICOH PRINTER USA in General While [+I8OO-8O3-1O69] is RICOH PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer service team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach RICOH PRINTER USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact RICOH PRINTER USA.
Oct 18, 2019 | Ricoh Computers & Internet
See all AcerView 54E 15" CRT Monitor Questions
AcerView 54E 15" CRT Monitor Logo
Ekse
Alun Cox
