Question about Garden
John deere lx172. whenever blades are engaged there is a horrible screeching noise and implement has virtually no power to cut even standard height grass, even on speed 1. maybe some kind of electric clutch?
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
Does the John Deere LX172 mower have an electric clutch and if so how do I operate it. I can't get my tractor to move.
Hi Bill, you electric clutch only engages your pto. The clutch for the Transmission just releases tension on an idler for the drive belt. Do you still have spring resistance on the clutch pedal?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 21, 2017 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
My 318 John Deere mower blades would not turnoff. The switch would not move. Even when I got off the seat the mower blades continued. I turned the motor off and now it won't start. Any idea?
Faulty attachmentment switch, replace it as it is sending a signal that it is engaged to your starter circuit, that is why it wont start.
It is also faulty as it wont engage the attachment (mower cutting deck)
Aug 03, 2015 | John Deere Garden
I just bought an old John Deere 68 riding mower but it does not cut grass even though the blade spins when engaged. I made sure the blade was on correctly but it still doesn't cut. I noticed the pulley...
Are you sure it is the correct blade and when it is turning the sharp edge is on the leading side? A spinning blade will cut grass even if the blade is dull. Did you lower the deck to the correct level?
Jun 28, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
