Question about Saws
Chicago tile saw parts
I need a replacement for the water tray on my saw, where can I find one?
  • 2712 Answers
SOURCE: Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
muttandjeff
  • 359 Answers
SOURCE: Water flows for cooling but saw does not rotate
check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Posted on Dec 03, 2008
SOURCE: need to purchase replacement part for a wts200l rigid tile saw
TILE SAW WTS2000L ;THE UNIVERSAL GUIDE CATALOG NUMBER #:6006001.I NEED TO BUY ONE
Posted on Apr 12, 2009
  • 54 Answers
SOURCE: Wet tile saw just stopped cutting; I only cleaned
How thick is the diamond bearing segment running around the rim of the blade? There needs to be at least an eighth inch. The last part contains no diamonds. If their is sufficient diamond left the material you were cutting may not have been abrasive enough to expose new sharp diamods. You can cut a small piece of asphalt. This will wear the matrix down so new diamonds are exposed.
Posted on Nov 19, 2009
Chicago electric bridge wet tile saw, model no. 62757. I need the reset button and harness that goes with it.
The only place you can buy parts for this is Harbor Freight Tools, this is there brand.
May 04, 2017 | Saws
Troubleshooting chicago 7" tile saw
problem power switch
brushes worn
problem armature
circuit breaker for power point
Jul 11, 2016 | chicago electric power tools 7" Portable...
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
I have a tile saw and the tray needs repaired due to small holes that have developed on the underside of the tray/pan from loading and unloading over time
If it is not a structural issue just clean the area and caulk it or even with some construction adhesive. Fibre glassing it may be an alternative.
Sep 15, 2014 | Saws
Rigid wts2000l WEt saw is not sending water to blade even though it is in on position
look for weak pump, or blocked pump pick up.
I have a similar saw, and the pickup at the pump gets pretty grimey, and ned to blow it out once in a while to keep it clean and of cake like tile paste. also check the hoses for splits and/or cloggs.
Jan 07, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
The arm that holds the motor to the tray, broke and cant find any replacement part, why is that?
Go to the Rigid web site and get their coustmer number they have replacement parts there.http://www.ridgid.com/ Shows you saw and parts for it.
Nov 11, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Wet tile saw just stopped cutting; I only cleaned the water tray??
Oct 04, 2009 | Dewalt D24000S Wet Saw With Stand
Need the Brick Carriage Rolling Bearings
i dont know where your located at, but when i need any parts for my tile saws i get them at the tile shop, that sells me the tile, most good tile distributors sell tile saws and most carry parts for saws targets a great saw and a good tile store will probably have those roller bearings in stock.good luck.chad
May 15, 2009 | Target Saws
Need to purchase replacement part for a wts200l rigid tile saw
Mar 11, 2009 | Saws
Saws Logo
43 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
