Question about Danby DDR6009REE Dehumidifier
Water not collecting
Dehumidifier running but no water is being collected
  • 8404 Answers
SOURCE: when I started my dehumidifier, fan and compressur
There may not be water to catch. It is winter (darn near), at least in the North (USA). I'm in the North East, neither of mine run very often this time of year. You don't say what your setting is ... it shouldn't be lower than 50%.
If you think it is still damp in the space you are concerned about, you can put a fan in the room to move the air around more. It could be that your room is really too big for your machine to actually monitor properly. That was the situation in my case, thus two units + a circulating fan for summer use.
I hope this helps you
thank you for your interest in FixYa.com
please vote
Positive comments are always welcome
thank s
a
Posted on Dec 07, 2009
heatman101
  • 43501 Answers
SOURCE: danby ddr4588ee dehumidifier runs, but there is no
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Jun 18, 2010
Sheikhtijani
  • 1284 Answers
SOURCE: Danby Dehumidifier Model # DDR557HE Serial #
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
Take care
Posted on Jul 23, 2010
heatman101
  • 43501 Answers
SOURCE: I bought a Dandby dehumidifier
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Posted on May 27, 2011
bobicehouse
  • 1524 Answers
SOURCE: My Danby R410A dehumidifier is
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the humidifier.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Posted on Jul 10, 2011
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
Haier DM30EA-L Serial #AJ0240E0200A99251074. Comes on and runs for a short time then goes off does not collect any water. Sometimes comes on agail, runs a little and quits again, no water collection. I...
heatman101
Apr 28, 2011 | Haier HDN655E Dehumidifier
My dehumidifer does not collect water. Model LHD459EL. It runs the specified time but hasn't collect water in several weeks.
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Mar 28, 2011 | LG LHD459EL Dehumidifier
My DD50E has stopped collecting water and filling up. It runs but doesn't collect water.
heatman101
Feb 17, 2011 | DeLonghi DDE50E Dehumidifier
Dehumidifier is running and the filter is clean but it hasn't collected water in a couple weeks. It is in the basement, which is very moist, so I know there IS water to collect!!
heatman101
0-
Feb 06, 2011 | Frigidaire FAD704TDD Dehumidifier
My dehumidifier star but not collect any water
heatman101
May 20, 2010 | Whirlpool AD70USS Dehumidifier
Crosley dehumidifier does not collect water.
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
Ebac xl Dehumidifier not collecting water
heatman101
Oct 11, 2009 | Ebac CS60 Dehumidifier Dehumidifier
Danby DDR6009REE Dehumidifier Logo
42 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
