Whirpool washer s/n20072300402-010477011-01 will not spin door will not open
How to remove the front panel of whirpool washer
SOURCE: front panel removal
make and model number would help, post these details and i may be able to help
Posted on Sep 09, 2007
SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
Posted on Jan 28, 2008
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
  • 1294 Answers
SOURCE: The door on my front end Whirpool Duet Washer will not open?
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
For the door to unlock, press & hold 'end of cycle' for 3 seconds, power shd be on for this, try door after 2 minutes. Your machine may not open if there is water inside, so first drain.
Posted on Apr 05, 2009
  • 240 Answers
SOURCE: GE Front load washer - cannot unlock door
manual lock release is located inside front panel. remove lower kick panel and reach up on latch side and feel for plastic tab hanging from lock asm. pull down.
Posted on Apr 27, 2009
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Why is my duet whirpool washer door not cycling through. It seems locked open
Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism. I found this at the Appliance Guru website.
Jul 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool washer front end loader lock light is on. but i can open the door the wash is empty. unplugged replugged it and tested the GIF the plug its in had power too, other wise the light to the lock...
unplug the washer, remove the lower front panel, put your hand under the front panel and pull a little lever behind the door lock mechanism and pull the door open.
Feb 05, 2011 | Whirlpool Washing Machines
I have a frigidaire affinity front loader washer that the final spin cycle won't work on. The rest of the wash cycle is fine and the basket spins for the other cycles just not the spin cycle. It is also...
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Mar 10, 2010 | Washing Machines
Wont spin or pump out
these wahers are problematic and expensive to repair. remove whirpool emblem on front and remove 1/4 screw pull top foward and up look inside of front panel and you'll see tech manual
Dec 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirpool
I would say to worry about it , if its flooding your house , need to open washer front panel ,start a new wash cycle and take a look to see where the water is leaking from , sounds like a broken hose under the tub that connects to the DRAIN MOTOR PUMP , AND BETTER have it fix right away cause if its getting to the main motor it could damage it , hope it helps AJ
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
After pulling the manual door release by removing the bottom door panel you are able to add 1 cap (1 tbsp) of liquid cooking oil to the water. The cooking oil will greatly reduce the amount of suds so you can complete the cycle.
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
