Hoover oph 148 flashing lights - Washing Machines
Daniel S
  • 4323 Answers
SOURCE: hoover oph 714d optima 7kg
Hi
Error code e005 means the temperature sensor has gone bad. To fix this error you'll need to replace the temperature sensor. It might have happened that the temperature sensor wires have been disconnected from the main board. To replace the temperature sensor you'll need to disassemble the washer and inspect the drum's bottom for the temperature sensor. Also check the wires coming to the sensor fro any cut.
Please post back for any further assistance.
Daniel
Posted on Aug 01, 2010
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
  • 6277 Answers
SOURCE: I have purchased a hoover
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 12, 2011
rebeccakidma
SOURCE: user guide manual for the
I have had this machine for 6 months now. I find it ok for a first machine. Its god for me : ie live alone, economical thinker, therefore fot wash only weekly, sometimes fortnightly and its great for that urgent "need it for later" wash.
I have got an "inkling" that your,query , is flasging the door etc because the previous cycle was either put,on hold by someone or you had a power cut.
The manual (which I lost, totally gutted bout that) says that our washer :), has a electric cut out memory board! Which u thought was brilluant on initial reading of thd instructions. ...however, when the street had a blck out, due to heVy rain.the cycle obvuously stopped but I didnot pannic as referred to manual....3hrs later. Machine started again. Went on for a while and it kept doing the same thing. Swush swush holdm swush swish hold,for at least Nother 2hrs. I was so worried. I had to turn it off. Then did a small cycle, which did as shud.
What im getting at is, I suppose u get what u pay for. Its alot of money u know but not compared to alot of machines. I think your machine is confused.
Before typing my essay I realised when u wud b readung it that you wud have had worked it out and I guess had done some more precious washin since. I reckon the trick is too treat our babies with love & attention and donr overload as it states exactly thar on nearly every cycle. (main reason im negative)....otherwise, my whites do clean white and it is quick and quite quiet
Posted on Jul 09, 2012
SOURCE: Hoover error E08
hoover oph 714d error code e08
Posted on Aug 04, 2012
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
Hoover troubleshooting
My Hoover Spin Scrub 60 will not spray on the wash setting but will spray on the rinse setting, what is the problem?
Jan 11, 2014 | Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover oph 148 stopped working through a cycle
I just had a similar problem to this with my Hoover OPH148 washing machine. The Cold Wash LED would flash 14 times repetitively after each wash cycle. The only way to open the door was to turn the controller to the off position.
I checked the heater element with a continuity test and found that the heater element had burnt out.
Hopefully this will help someone else if they see the same condition.
Jul 18, 2012 | Washing Machines
Hoover optima oph714ds error code e14
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Dec 24, 2010 | Washing Machines
Hoover oph 614 on the front at the bottom ther is a filter i took that out and then screwed it back in today did my washing and there was water all over the garage floor. i noticed the seems to be coming...
Had the same problem today. Found a very small piece of lint/fluff in the sealing groove of the filter socket. Removed this with an orange stick & touch wood the floor is dry again.
Do hope this helps
Oct 26, 2010 | Hoover AAA160 Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
