Does your window air conditioners have drain holes for outside drainage..Haier 10,000 btu ESA410M-L
2 Suggested Answers
  • 67 Answers
SOURCE: how large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Posted on Jul 21, 2008
II HAVE CODE EO ON MY HAIER ESA410M-L WINDOW
try to drain the water from the unit it should have drain holes in the back of unit on the bottom make sure they are cleaned out where they can drain the condensate water out of the unit
Sep 03, 2014 | Heating & Cooling
Why is water leaking on the floor from my haier air conditioner
Window A/C units will dehumidify the rooms as they operate. The unit has drainage at the rear. It is important when installing the unit to ensure that the unit slopes slightly OUTWARD to allow the water to drain to the rear. Otherwise the drain pan fills and the water pours into the room. If the unit IS tilted outward, then check the drainage holes for obstructions.
Aug 01, 2014 | Haier HWR08XC7 Air Conditioner
Where is the drainage hole on this unit?
Some don't have drain holes.You can make a hole by drilling the chassis. Some just have to be installed with a slight lean to the back so they drain properly.
Jul 12, 2014 | Haier ESA408KE 8,000 BTU 10.8 EER Fixed...
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
I have a 6000 btu window unit. I was wanting to know how the unit drains the water. where does the water come out of the unit at? I could not find a drain hole.
No drain holes on most units that size
The water gets from the front evaporator thru
a small hole you can not see
Then it finds it's way to the outside or back on the
bottom metal pan
It is evaporated by the condensor fan
It may drain out over the rear pan lip, if
it gets alot, but no drain hole is necessary
You can angle the unit down at the outside or
rear & you can drill a small hole, but it uses the water
to cool the condenser
Aug 04, 2011 | Haier HWR08XC7 Air Conditioner
Whirlpool Air Con Drainage issue
Yes, there should be a place for the condensate to drain outside. It's apparently clogged and the drip pan is overfilling. Look for a tube or an opening outside where the condensate should be exiting. This needs to be unclogged.
May 31, 2009 | Whirlpool Electronic Window Air...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
