Replaced thermostat but it did not correct. it continues to run when thermostat is turned off.
Pull the stat off the wall, if the unit fan continues to run then your fan relay is bad or receiving 24vac from another source.
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
