Linksys wrt120n won't connect to hp pavillion dv4
  • 386 Answers
Hi David,
First thing you can do is a ipconfig /release /renew
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your networkLinksys wrt120n won't connect to hp pavillion dv4 - icon1.png settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Routericon1.png.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you\'ll have to redo the security settings.
Hope this helps!
Please Rate;)
Gary
Posted on Jul 18, 2013
4 Suggested Answers
  • 252 Answers
SOURCE: How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Posted on Nov 07, 2009
govinda123
  • 2263 Answers
SOURCE: How to configure our router, linksys wrt120N,
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Feb 05, 2010
govinda123
  • 2263 Answers
SOURCE: unable to connect to the internet with my linksys
If you connect the computer directly to the AT&T modem , it work. That means the modem is working properly.
AT&T is DSL connection type. the DSL connection works on 2 different modes. 1) DHCP 2) PPPOE.
Now you will need to connect the modem and the computer to the router. open the set up page of the rotuer.
The set up page is the page where you can change the settings of the router.
According to the type of internet connection you can change the settings of the router
Click Here for step by step by instructions
Posted on Feb 16, 2010
How do I find network key for wrt120n router
You will need to check the setting of your wireless router.
Do you have any computer connected to the network?
Using one computer connected to the network, you can open the router page and check the wireless router settings.
Check this link for Linksys WRT120N router setup and troubleshooting
Oct 15, 2014 | Linksys WRT120N Router
My WRT120N access-point has a WAN connection to a Star Band dish. These dishes usually operate at half-duplex, and most ethernet connections, such as the WAN port of a WRT120N, operate at full-duplex. This...
OK,
You can login to the lan port by its IP address or software and then navigate to the appropriate settings. I am not sure if you can toggle duplex settings. I had this one and its great. check out this site Linksys Official Support Linksys WRT120N Wireless Home Router
Nov 28, 2017 | Computers & Internet
How can I assign a pasword to my linksys cisco wrt120n so i don't have to use the pppoe on my computer
if you have pppoe on your computer, you need to input your username/password on your linksys router. so that you wont have to input anymore to your computer whenever you connect to the internet.
Jul 13, 2012 | Linksys Cisco-Wrt120n Wireless-n Router...
How ro connect HP printer DESKJET 3050
This model printer does not have a network connection therefore to print via wireless from the laptop, the printer needs to be connected to a computer and setup as a shared printer. This computer must be connected to the wireless router with a LAN cable.
Jul 04, 2012 | Linksys WRT120N Router
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
You can do it manually without CD.
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
Oct 13, 2011 | Linksys WRT120N Router
My wii will not connect to my linksys wireless router
Is it a new router? Your Linksys WRT120N needs resetting. Reset the Linksys router & reconfigure as per your requirement. I had two such routers giving trouble for the WiFi connectivity & which were new. You will be able to connect your router.
sonsunny
Jul 08, 2011 | Linksys WRT120N Wireless Router
How do I reset my router password
Here is the step-by-step instruction to reset Linksys WRT120N Router
  • First af all you have to make sure the power is "On" . Power the router up while pressing the reset button located at the back of the router using pencil or paperclip
  • After around 30 seconds you will be prompted with the boot loader. Connect the boot loader using the standard IP address if you have not changed it (http://192.168.1.1)
  • Upgrade the firmware to the latest one from Cisco site
  • Power cycle the router and allow it to come up.
  • When it is fully up, press and hold the reset button for 5 secondsThe LED light will blink indicating that you're done holding the reset bottom. If the Power LED won't blink try to press and hold the Reset Button for I minute and then power cycle the router for another 1 minute.
  • Power cycle the device and now you have reset your linksys WRT120N router See the following link if you forgot to setup linksys router
(http://infoteknotainment.com/reset-linksys-wrt120n-router)
May 24, 2011 | Linksys WRT120N Router
WRT120N how to enable wireless option
Wireless should be enabled by default on the router. Check whether you have switched on wireless on your laptop.
Please rate if helpful.
Thanks
Apr 13, 2010 | Linksys WRT120N Router
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
