Question about Dell 924 All-in-One InkJet Printer
USB Cable? I have a DELL Dimension 8110 PC and a DELL Photo 924 printer. They won't communicate right now. I know where to plug the wide-socketed end of my USB cable into my PC. But where does the other end go?
    Sergeant:
  • 279 Answers
It should connect directly to the printer. Exactly where varies from model to model, but there should be a small port it will fit in. Just FYI, the printer will not be powered by the USB cable, it will require a separate power cord (which you probably already knew and had plugged in).
Posted on Aug 28, 2007
SOURCE:
Dell 924 printer. Stopped working - when try to
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Dell photo 924 is completely unresponsive. Power
Pitch it. There does not appear to be a firmware update. That would be the only thing that would have a chance of fixing this. Otherwise, the controller board is shot. The cost of repair is more than the printer, buy a new one.
Oct 26, 2009 | Dell 924 All-in-One InkJet Printer
I had a paper jam this morning, cleared the paper jam, and now the printer will not power up. I tried to remove the usb cable, and the power cable, reboot the computer, and replug in the usb and power...
First, Make sure that the printer is properly plugged in to a working electrical outlet and that it is hooked up to the computer as indicated. There should be two separate cables running out of your Dell 924, a power cord and a USB cable that communicates with the computer. If both of these aren't plugged in, then the machine will not function properly.
If the lights on your printer aren't working then it means one of two different things:
  • Printer has an internal electrical problem and needs repair or
  • Printer isn't receiving power from the outlet or power cord
Check whether, are you getting power from the socket by connecting some other component..If it works check whether the Power cord is propwerly connected, try pressing the power cord once..
If not the circuit may be damaged, Which cant be repaired inhome, you have to return to DELL service center and make it repaired
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 09, 2009 | Dell Photo 964 All-In-One InkJet Printer
My dell photo 942 won't scan
I would try deleting the scanner driver and software and reinstall. then plug the usb cable from the printer to the pc.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Dell 924 All-in-One InkJet Printer
Dell 924 - can't fnd manual - don't think it's hooked up right
You need a power lead to the printer and a usb lead going between the printer and the computer. The manual is available to download at http://support.euro.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
Jan 20, 2009 | Dell 924 All-in-One InkJet Printer
I cant figure out what the printer power cable is for my Dell 924
If you are talking about the cable that plugs into the wall socket, it shoudh have a 3 prong plug that goes to a square block that fits into your printer.
Jan 08, 2009 | Dell 924 All-in-One InkJet Printer
Where is the printer hookup on this computer?
if it is a 25 pin parallel cable there should be only one place to plug it, if it is USB you can put it in ANY USB socket
Oct 04, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 4500
connect this cable to socket, which is in left right corner of motherboard (its on the left side of the bottom pci)
Feb 26, 2008 | Dell Dimension 4500 PC Desktop
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
