Question about Cameras
JCC-27B camera have this camera on my motorhome as a rear view camera have sound n screen is blank-white can you tell me what is wrong.Replacedcable 2 years ago and it worked fine for awhile
JoeO700
  • 80 Answers
SOURCE: blank lcd screen when camera is on
If the LCD is all white when this occurs it is the LCD that is at fault. Verify this by shooting a couple photos, if the photos look good when viewed on a computer, the CCD is not at fault. The LCD module has had problems with the harness that connects it rubbing againts the metal frame of the camera and causing similar problems. Hope this helps you. Joe Weibel customelectronics.org
Posted on Feb 16, 2007
SOURCE: A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Posted on Mar 19, 2008
t00nz
  • 4738 Answers
SOURCE: cannot take pictures
Sounds like you might be in luck. These symptoms sound very much like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Apr 21, 2008
sharcnet
  • 2130 Answers
SOURCE: LCD screen stopped working
Does the camera take good pictures? Have you tried downloading them into a PC? If the pictures look OK on the PC but not on your camera's LCD screen, then the LCD screen is most likely defective.
Please read this article that I wrote regarding LCD screen replacement.
http://www.fixya.com/support/r370257-replace_defective_lcd_screen_in_kodak
Posted on May 16, 2008
SOURCE: Blank white screen
The problem is that the heat by the chassis of the screen LCD melts the insulating material of some electric cords located behind this one ( when the cords are in contact with the chassis).
To fix the problem it is necessary to disassemble the apparatus by the four back screws, to check the cords (red and black and on the upper part on the right on mine) and to do again insulation
Posted on Aug 11, 2008
Had one installed in motorhome. Only problem when it is switched to viewing of traffic on Road behind that it is in mirrored reflection. Seems a little dangerous.
Your question infers a Backup Camera. If I knew its make and model number, I might be able to pull up a copy of your owner's manual for it and find an answer.
The camera screen in the dash should display the same image orientation as the rear view mirror. If it is opposite to the mirror, you indeed have a dangerous situation.
Mar 28, 2018 | Cars & Trucks
Black screen pops up states caution your screen may seem reversed
I'm assuming this is a DVD player or at least contains a video screen. The message you are seeing sounds like the rear camera input has been activated. They give this alert to inform drivers that the view through the rear cam may be reversed. Most cameras have a switch setting to allow this adjustment.
If you do not have a rear camera installed, then it sounds to me like the rear camera trigger has been improperly connected. This is a wire that when it sees a 12-volt signal, activate the rear cam input on the radio. If you do not have a rear camera, this wire should not be connected. You did not give a make/model so I cannot begin to guess the wire color, but look for a wire that is not either black, red, yellow, white, gray, green, violet, or blue (with or without stripes). There is no standard color for this wire. Some Alpine units use orange/white, but on most radios, this is a dimmer wire. Pioneer and Kenwood often use a light purple or purple/white.
Find out what wire is for reverse camera and disconnect it.
Dec 19, 2013 | Car Audio & Video
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
Screen white, pcitures white when I take them. Can view stored pictures from card,,,batteries new
call Fuji and tell them that you would like to send in your Finepix to see if the cheap/defective SCR chip was used in your model. If so, they will fix for free.
Apr 26, 2009 | Fuji FinePix Z10fd Digital Camera
White preview screen after pic taken
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Nov 20, 2008 | Fuji FinePix S7000 Digital Camera
May 02, 2008 | Kodak EasyShare V1003 Digital Camera
Blank lcd screen when camera is on
No solution for your first problem but it's normal that you cannot view your photo on the LCD screen before actually taking it. Due to the way a reflex camera is built, you can't have a live view on your LCD. The Fuji S3 Pro has this type of preview as also most recent camera (Nikon D300, Canon 40D...).
Dec 08, 2007 | Fuji FinePix S3 Pro Digital Camera
Coolpix nikon digital camera
This sounds like a broken or cracked LCD screen. The backlite is working, thus you will get the white screen. The LCD could also be disconnected internally, or has other problems. But this is a direct problem with the LCD.
A camera like this can usually take pictures, and you may be able to use it to set the menus by using the video cable to the TV or computer screen (some flat screens have video inputs).
Dec 04, 2007 | Nikon COOLPIX L3 Digital Camera
Blank camera screen
I hope you sent it back to Fuji before your guarantee ran out.
Sep 07, 2006 | Fuji FinePix E550 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
