Question about Garden
Need pic of clutch spring placement craftsman lt1500
Briggs & Stratton 112p02-0117-F2 carburetor on a craftsman 580.752880 pressure washer spring placement.
Carb part number is 799447, just google the number, you can order it from multiple sources including Amazon probably between $45-75
Apr 26, 2017 | Craftsman Garden
Headlights on my craftsman LT1500 riding mower won't shut off
bad switch. you can just unplug the if you like. wont hurt anything
Mar 08, 2017 | Craftsman Garden
While cutting grass with sears craftsman LT1500 17.5hp 42"deck why is mower losing power within 2 min after I put in gear and begin to now. I have to keep shifting up to a higher gear in order to mow
First check your air cleaner for clean filter. If that's clean then ajust your valves. Start with intake and exhaust set at .004 each. I think this will fix your problem. GOOD LUCK FRIEND.
Jun 09, 2015 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
How do I get the deck to rasie higher on craftsman lt1500 lawn tractor?
1 and 2 are ok to drag on the ground. I use this to clear weeds from my overgrown gravel driveway.
Jul 15, 2014 | Craftsman Lt1500
Clutch cable spring wearing through then breaking
Use thick bearing grease between the clutch spring and where it is coming in contact with that is causing the spring failure. This should extend your springs life. Check for any alignment issues that would cause the clutch spring to prematurely wear and break. The grease is just a temp. repair to extend spring life. Hope this helps.
Oct 11, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to install clutch in craftsman lt 1000
there is no clutch,, you have an arm with a pulley that is spring loaded .. when u release the " clutch" this arm pulls a pulley against the belt taking up the slack ,, make sure the belt is not worn ,, or the spring is broken or loose
Apr 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
