Holiday8 green carrier air conditioner
Do i have to vent to outside
bobotfel
  • 236 Answers
SOURCE: Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
Actually dry and moisture setting cannot cool your room because in that sitting the temperature is limited, you have to set the control in cool or auto.. If the unit is blinking try to reset the unit by disconnecting the power supply for 10 sec.("on" & "off" the circuit breaker), and test the unit.
But if wont work the unit have some defect it may be the thermistor, low freon, or the outdoor unit have some problem. Check if the outdoor and indoor unit is clean or you to call a qualified technician for this problem.
Posted on Mar 27, 2008
  • 587 Answers
SOURCE: My air conditioner runs outside, but there is no
If your Indoor Coil is Froze Up, you need to shut the unit off and let it thaw out. After it thaws out for several hours, then turn the blower on at the thermostat, you’ll see a switch that says fan on/ auto
Move the switch to on and see if the blower runs if it does let it run another hour or so. Then shut it off and check your filter and indoor coil to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant. If the blower doesn’t run when you turn the switch to on then you need to check the blower out,
If your not familiar with any of this then you need to call a service tech.
Posted on Apr 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Posted on Apr 30, 2009
  • 68 Answers
SOURCE: Describe your Kenmore Air Conditioner Proble. My
the vent is a fresh air intake, when it is pulled open you are mixing outdoor air in the unit. when it is hot and humid outside you will make the unit struggle to cool. Leave the vent closed.
Posted on Aug 23, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Apr 30, 2009 | Carrier BCA101R Air Conditioner
No cold air blowing from vents
faulty indoor fan motor, check for blown fuses first in the indoor fan unit first before replacing motor. i live in s.a to i feel your pain.
Jan 29, 2009 | Heating & Cooling
I am living in a home with a carrier furnace. The furnace is in the back part of the house in a store room. It has two- 2 1/2 inch plastic pipes. One that suppplies air to the furnace and the other is...
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
Oct 30, 2008 | Carrier Heating & Cooling
Blower Turns off if ac unit comes on. No air coming through vents
This only could 1--2 things, a bad circuit board fan relay or bad thermostat. To check for bad thermostat, take off the front cover to reveal the 4-wire terminial and jump the red-wire (power)-cool,(yellow -y or blue)--- green--fan white-(heat)..........red to yellow-or y=cool. Thank-you-very-much!
Aug 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
AC Compressor running outside but no air coming out of inside vents.
Can you say, WOw, Icould've had a v-8 moment! I think you answered your own question or you are not far from the answer. (let me direct you, either the thermostat or the little door on the duct going to your room! Thank-you-very-much!
Aug 01, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
