Question about Freezers
Frigidaire fre196a my fridge is not working even on mark 7 but my freezer is, what seems to be the problem?
4 Suggested Answers
  • 121 Answers
SOURCE: Frigidaire Fridge/freezer works then doesn't work???
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
Posted on Sep 23, 2009
  • 47 Answers
SOURCE: Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Posted on Nov 11, 2009
brownline45
  • 310 Answers
SOURCE: Hotpoint Iced Diamond fridge freezer, fridge seems
In case the freezer not getting cold. maybe the tube is leaking .the freon gas scape. or your compessor is defective
Posted on Jun 25, 2010
Why does the light flicker when door is opened. The freezer seems to be working at this time.
It could be the button door switch that controls the light, or that a florescent lamp is being used in the cold fridge,
Oct 30, 2015 | Frigidaire Freezers
Frigidaire fre196a
I would check to see if the compressor is running. If it is very hot and not humming then the comp is done for. or very hot and you can feel it running constantly the you have a leak and note enough refrigerant. If you hear it run then click then run then click and if hot the comp is done for and needs to be replaced.
Apr 01, 2014 | Freezers
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
What temperatures do the 1-7 reading on the temp. dial correspond to.
In all frdige freezers, 1-7 is -18 to -21 approx in the freezer and between 2 and 4 in the fridge. This may vary from system to system but not by much. Obviously, 7 is the coldest as this makes it the most difficult for t he thermostat to disengage.
Dec 10, 2009 | Frigidaire Freezers
Frigidaire FRE196A
Nov 11, 2009 | Frigidaire Freezers
Sep 23, 2009 | Frigidaire Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
My fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
Aug 11, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezers Logo
14 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
