Laptop lg r38 - Computers & Internet
On my Kubota M135X the error code r38 appears what is the problem
What are you doing when that error code appears?
Jul 27, 2014 | Garden
ERROR CODE R38
What will the machine not do could not find that code
Feb 13, 2014 | Konica Minolta Magicolor 4690MF...
Cannot Recieve faxes
usually caused by noise in the phone line have the phone company check the phone line or could be the marketing area is set wrong make sure it set to the correct country
Mar 06, 2013 | Konica Minolta Bizhub C360
R38 Open Circuit what is value
What do you mean?
Its a low power PSU to use at modern board, 500W should be the minimum requirement for todays board!
Dec 10, 2010 | Antec SL300S 300W Power Supply (045176)...
Looking for replacment keyboard for lg 510 laptop originally purchased in spain no seems to have one and lg uk are hopeless
I searched lg.com in the USA and they didn't have an lg 510 laptop listed. I'm afraid that it is not supported here either.
Maybe try ebay.com for parts for it, or look under a related product that uses the same keyboard.
Sorry.
Good luck on finding the keyboard for your laptop.
Jul 22, 2010 | LG Computers & Internet
The dfx doesn't switch off with either the foot switch or the front panel switch
http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf Heres the schematic. Check the footswitch jack for bad solder joints to the board. If the channel indicator isn't lighting up check for 5 volts at R38 and R39. If you have no experience with troubleshooting I wouldn't recommend working on the amp unless you learn more about the subject. To start do not work on the amp while it is powered up as the capacitors store a lethal charge and even if you don't get hurt it is easy to damage components via a short circuit. I hope some of this helps.
Aug 04, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
I HAVE A ROOM 21X32 HIGH CEILING. WHAT IS THE BEST SPLIT HEATPUMP TO INSTALL.
I myself am a fan of ductless splits. I would recommend either Mitsubishi or Daikin
Jul 07, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Ups apc su3000rm3u resistor wrong
well it could be your mosfet is leacking and some of the those traisitor is spoil check the black color of all the tranistor as well
Jan 23, 2009 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
I need R38-td3 driver
You can get the latest ATI drivers here:
http://ati.amd.com/support/driver.html
im pretty certain that every card with one GB of ram will be supported, so try the newest version compatible with your OS...
Jan 21, 2009 | Computers & Internet
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
