Question about HTC Cell Phones
Dialog boxes When I boot my computer I get a dialog box labeled "htc_http_dialog" that contains the text "TODO: Place dialog controls here" with an OK and a Cancel button. Nothing else is present. This appears to be part of an incomplete startup application. How can I repair or remove this box from appearing?
SOURCE: volume control appears on screen uncommanded and cannot be sent away
I had exactly the same problem. The volume up button was constantly on, causing the on screen display to be permanently displayed. Here is the solution to fix it. This will also work for any other front panel buttons that are misbehaving.
Note: If you monitor is still under warrantee, don't try and fix it yourself - just send it back.
If you open your monitor you will find a small circuit board with a row of microswitches mounted on it. This is the circuit that's causing the problem.
To open your monitor you will need to remove the stand (one plastic cover that unclips by hand and 4 screws that can be removed with a philips screwdriver). This will then reveal two additional countersunk screws that need to be removed.
You can now remove the front cover. There are 4 clips at the base of the cover that can be removed by hand. You then need to pry the cover off, starting at the corner next to the power button. This is really quite stiff and you need to use a reasonable amount of force. Don't worry about the loud cracking sound as each clip along the side releases.
Once the cover is removed you will see the circuit board with the microswitches staring you in the face.
This board needs to be replaced but if you want to fix the problem immediately here is what I did.
Disclaimer - Proceed at your own risk from here on in.
Plug your monitor back into the power and reconnect to your PC. Make sure it's on and still showing the same problem.
The curcuit board unclips and there is a 7 pin connector that also can be unclipped. Remove the board and undo the connector. You don't need to switch off the power.
After the board has been removed for a few seconds, the on screen display that was permanently visible should disappear.
Now I temporarily disabled the malfunctioning button by bending the associated pin on the connector 90 degrees and then reattaching the connector.
How do you know which pin is associated with which button. Trial and error. Simply bend down a pin, and reattach the connector. If the problem persists, unplug and try the next pin.
When you've found the correct pin, straighten the others and reattach the connector.
Clip the curcuit board back in, making sure the connecting cable is clear and doesn't get pinched.
Reassemble your monitor and you're good to go.
The next step is to order a new circuit board from Philips. These should be really cheap (I hope) and you now know how to fit it yourself.
I'm going to try ordering one tomorrow.
Mark Gladding
Posted on Aug 04, 2008
sandrew
  • 2961 Answers
SOURCE: The Safely Remove Hardware dialog box does not appear
not really, you may be able to select the option, if you right click on the drive in my computer, but they don't always disconnect the hardware anyway, so just remove it as lons as you know there is no activty
Posted on Aug 24, 2008
frcs68
  • 1605 Answers
SOURCE: on startup, i get the message: Isass.exe - Access Denied
looks like the windows login authentication having a problem authenticate your login.
go to "safe mode with network connection" and check the laptop for virus. go to Trendmicro and get the house call (online virus scan).
option is copy a good lsass.exe from another laptop or desktop pc and replace it.
"lsass.exe" is the Local Security Authentication Server. It verifies the validity of user logons to your PC/Server. It generates the process responsible for authenticating users for the Winlogon service. This process is performed by using authentication packages such as the default Msgina.dll. If authentication is successful, Lsass generates the user's access token, which is used to launch the initial shell. Other processes that the user initiates inherit this token. More info
Note: The lsass.exe file is located in the folder C:\Windows\System32. In other cases, lsass.exe is a virus, spyware, trojan or worm!
Posted on Oct 29, 2008
kasap
SOURCE: UNABLE TO BOOT htc touch pro
voldown, central key and reset botom at the same time, then text appear, choose number 1 for restore manufacturer default pressing volup or 2 for restore munufacturer default and format moviMand pressing voldown and wait a few seconds.
Posted on Nov 03, 2008
SOURCE: Text message icon won't turn off
It is probabily because u have unread or old Messages stored in the SIM card.
Posted on Dec 31, 2008
What is a dialogue box and how do I close it?
A dialog box is a temporary window an application creates to retrieve user input. An application typically uses dialog boxes to prompt the user for additional information for menu items. A dialog box usually contains one or more controls (child windows) with which the user enters text, chooses options, or directs the action.
In most of the cases, you can close a dialog box by clicking on the 'X' button located on the top-left corner of the box. Else, you can click on the options like 'Close' or similar ones (if applicable).
GuruAid.com
Mar 01, 2015 | Microsoft Computers & Internet
Tip
Rotating Text in Cells
In Excel, text of cells can be rotated to any direction or to a certain angle. It is called the orientation of the text. By default, orientation of text is horizontal.
To change the orientation of text, follow these steps.
  • Select cell or range of cells that contains data you want to rotate.
  • Select ”Cells” command from “Format” menu OR Press Ctrl+1, Format Cells dialog box appears.
  • Click Alignment tab of dialog box.
  • Specify angle in ”Degrees” spin box of orientation section.
  • Click “OK” button of dialog box.
on Jan 29, 2010 | Computers & Internet
How do i enable cookies on my web browser?
Internet Explorer 6 for Windows
  1. Within Internet Explorer, click the "Tools" menu and choose "Internet Options."
  2. Click the tab labeled "Privacy."
  3. Click the button labeled "Advanced."
  4. Check the option labeled "Override automatic cookie handling." To enable cookies:
    Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Accept."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "First-party Cookies" (and "Third-party Cookies, if you wish) to "Prompt."
  5. Click "OK" to save changes and close the dialog box.
Firefox for Windows and Mac OS X
  1. Open Options dialog box: WindowsWithin Firefox, click the "Tools" menu, then click "Options."Mac OS XClick the "Firefox" menu, then click "Preferences."
  2. In the left-hand column, click the icon labeled "Privacy."
  3. Click "Cookies," then click the option labeled "Allow sites to set cookies.
  4. Click "OK" to save changes and close the dialog box.
Safari for Macintosh OS X
  1. Within Safari, click the "Safari" menu and choose "Preferences."
  2. Click the icon labeled "Security." To enable cookies:Set the option labeled "Accept Cookies" to "Always."
  3. Click "OK" to save changes and close the dialog box.
Internet Explorer 5 for Windows
  2. Click the tab labeled "Security."
  3. Click the button labeled "Custom Level."
  4. Scroll down to the section labeled "Cookies." To enable cookies:Set "Allow cookie that are stored on your computer" to "Enable."Set "Allow per-session cookies" to "Enable."To receive a prompt to accept or decline cookies on a site-by-site basis:Set "Allow cookie that are stored on your computer" to "Prompt."Set "Allow per-session cookies" to "Prompt."
Internet Explorer 5 for Macintosh
  1. Within Internet Explorer, click the "Edit" menu and choose "Preferences." (In OS X, click the "Explorer" menu and choose "Preferences.")
  2. In the left-hand column, click "Cookies." It is is listed in the "Receiving Files" group.
  3. Click the button labeled "Custom Level." To enable cookies:Set option labeled "When receiving cookies:" to "Never Ask."To receive a prompt to accept or decline cookies on a site-by-site basis:Set option labeled "When receiving cookies:" to "Ask for each site."
Internet Explorer 4 for Windows
  1. Within Internet Explorer, click the "View" menu and choose "Internet Options."
  3. Select "Custom" and click "Settings."
  4. Scroll down to section labeled "Security." To enable cookies:Select "Always accept cookies."To receive a prompt to accept or decline cookies on a site-by-site basis:Select "Prompt before accepting cookies."
Opera 7 for Windows or Macintosh
  1. Within Opera, click the "File" menu and choose "Preferences."
  2. In the left-hand column, select "Privacy."
  3. Select the option labeled "Enable cookies."
Netscape Navigator 6 and Higher for Windows and Macintosh
  1. Within Netscape Navigator, click the "Edit" menu and choose "Preferences." (In OS X, click the "Netscape" menu and choose "Preferences.")
  2. In the left-hand Category column, click "Cookies." It's listed in the "Privacy and Security" group. To enable cookies:Select "Accept all cookies" or "Accept only cookies that get sent back to the originating server." To receive a prompt to accept or decline cookies on a site-by-site basis:Check the option labeled "Warn me before storing a cookie" and select "Accept all cookies" or "Accept only cookies that get sent back to the originating server."
Aug 28, 2011 | HP Computers & Internet
How to change the language
Hi!
Please try doing the steps below:
1. Open Control Panel and double click on the Regional and Language Options icon.
2. In the first tab, Regional Options, select English (US), English (UK), or any other English (there are many versions of English pre-loaded) as per your wish. The option is available in the first drop down list under Standards and Formats. You may also click the Customize button next to the drop down to customize the format of date, time, currency etc.
3. Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings.
4. To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences. Please note that you can also use the Language bar to switch among languages. Click OK to close the dialog box.
5. To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box.
6. Click OK to close the dialog box and log off for the settings to take effect.
Hope this helps. Thanks for reading my suggestion.
Apr 18, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
The settings are all in arabic and i want to change it to english.
The following steps explain how to change computer language to English in Windows XP.
2. In the first tab, Regional Options, select English (US), English (UK), or any other English (there are many versions of English pre-loaded) as per your wish. The option is available in the first drop down list under Standards and Formats (see Fig 1). You may also click the Customize button next to the drop down to customize the format of date, time, currency etc.
3. Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings (Fig 2).
4. To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences (Fig 3). Please note that you can also use the Language bar to switch among languages. Click OK to close the dialog box.
5. To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box (See Fig 4).
6. Click OK to close the dialog box and logoff for the settings to take effect.
Read more: http://www.brighthub.com/computing/windows-platform/articles/46362.aspx#ixzz1HJ2GSGTU
Mar 22, 2011 | Computers & Internet
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
How do i delete texts from my htc hero with large conversations
When you go into your MMS app, you will be presented with a list of people you have texted and the number of texts with that thread (conversation). Long hold on the thread you want to delete and you will get a dialog box. One of those options is Delete, and then another dialog box that will ask you if want to delete the entire thread. Hit ok, but keep in mind that if it's a long thread, it may take a couple of minutes to delete. Please be patient with this.
Good luck.
Oct 20, 2010 | HTC Hero Smartphone
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
I need to install or downloads Arabic language into my computer languages so I can type using Arabic keyboard thank you very much sam
Setting Up Arabic in Windows XP
Adding the Language to Windows
The following instructions will help you to set up your keyboard layout for Arabic that matches the DataCal Keyboard Labels.
Step 1. Install Supplemental Language Support
The Arabic language requires that you install Supplemental Language Support before you can set it up in Windows.
  1. Select the Start button in the lower left corner of the Desktop.
  2. Select the Control Panel (or, if you are using the Windows Classic Setting, select Settings > Control Panel).
  3. In the Control Panel, double-click the Regional and Language Options item.
  4. In the Regional and Languages dialog box, click on the Languages tab. In the Supplemental language support section, click on the Install files for complex script and right-to-left languages (including Thai) option (see Figure below).
  5. Click on the Apply button in the lower right corner of the dialog box and then click on the OK button. You may be prompted to insert your Windows install CD into the CD drive.
Step 2. Add Language to Windows
  1. In the Control Panel, double-click the Regional and Language Options item.
  2. In the Regional and Languages dialog box, click on the Languages tab.
1. Click on the Details button in the Text services and input languages section of the Language tab to open the Text Services and Input Languages dialog box.
2. To add a language, click the Add button in the Installed services section to open the Add Input Language dialog box.
3. Click on the arrow to the right of the selector in the Input language selector and scroll to Arabic.
4. The Keyboard Layout/IME should default to the Arabic keyboard layout. If it does not, click on the arrow to the right of the selector in the Keyboard layout/IME selector and scroll to the Arabic keyboard layout. Note that there often are different keyboard layouts for a language. You should select the language and keyboard layout that matches the DataCal Keytop Label.
5. After you select the language and keyboard layout, click on the OK button to close the Add input language dialog box.
6. When you return to the Text services and input languages dialog box, you will see the new input language and keyboard layout included in the Installed Services box.
7. Click on the Apply button to apply the changes to the new layout. Note that each language features a small blue box in the Installed services section with 2 letters that indicates the language. English is designated as EN.
  1. If you do not wish to add any additional languages or layouts, you can click on OK to close the Text services and input languages dialog box. When you return to the Windows Desktop, you can see the language bar in the lower right corner of the Desktop.
  2. To change the language and keyboard layout, click on the two-letter language selector box with the left mouse button to open the language selector menu.
  3. Click on the language that you wish to use in the language selector pop up menu.
The language you select will remain in effect in active Windows application until you select a different language. For example, if you select the Arabic language and keyboard layout in Microsoft Excel and English in Microsoft Word, each application will use that keyboard layout until you exit the application or you select a different language.
Default Keyboard Layout
If you wish to make a particular keyboard layout the default Windows layout (i.e., to be used in all Windows applications), open the Text services and input languages dialog box.
Select the desired keyboard layout to be the default in the Default input language section of the dialog box.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 27, 2010 | Microsoft Windows XP Professional for PC
Code 10 cd/dvd
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Oct 07, 2009 | Computers & Internet
Cell Phones Logo
149 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
