Question about Garmin GPSMAP 492 GPS Receiver
Satellites wont my receiver will not track satellites when you power it up. Any idea? Has a internal intenia
Gog 2816 satellite reciever, cant tune as i dont know the password. how can i reset it?
Instructions
    • 1 Check the TV and make sure the channel is set to 3 or 4 for the primary TV set, or channel 60 for the UHF (secondary) set, if the receiver is a "dual-mode" device.
    • 2 Check all connections on the back of the receiver. Make sure all cabled connections are tightened and all plugs are securely plugged in.
    • 3 Check for a key card loaded in the card slot on the receiver. If you have a key card, slowly and carefully remove the key card. Leave the card out for at least 30 seconds, and then re-insert the card.
    • 4 Unplug the main power cord from the back of the receiver. Wait at least 30 seconds and then plug the power cord back into the receiver.
    • 5 Press the "Power" button on the front of the receiver to power on the device. Allow the receiver several minutes to acquire a signal and download any additional updates. The receiver is reset.
Read more: How to Reset a Satellite Receiver ' eHow.com http://www.ehow.com/how_2127605_reset-satellite-receiver.html#ixzz2Qyh3yF2m
Apr 18, 2013 | Computers & Internet
I have a Magellan 315 gps that is appoximately 10 yrs. old. Does it have an internal battery that needs to be replaced?
Not a fix, shared information.
Yes these units have an internal ten year lithium battery. I am currently researching this issue, as I have two dead and one working 300series GPSs. When the internal battery dies and the regular batteries are removed or die the unit will loose all user data (way points and routes), as well as the satellite map and initialization. After dieing the unit will appear to function normally but fail to lock on, track or get a fix. Only showing the coordinates from the initialization. These units also have an internal capacitor that provides sufficient power to hold the memory during quick battery changes, but not over night. I have as yet found a working solution, but only researching this for a few days.
barang at asia period com
Nov 19, 2010 | Magellan GPS 300 GPS Receiver
I have a Maxx Digital explorer GPS .It keeps reading "unable to locate Satalite".Any Idea's?
You should be able to set it to track more than one satellite, my garmon can track up to 20 at a time, and it's over 5 years old. Go into your satellite settings and see how many satellites you are currently tracking. Also if you are having extremely over cast conditions this coud happen, but should clear up, eventually. Try setting it to track the maximum number of satellites and see if this resolves your problem.
Oct 14, 2010 | GPS
GPSmap 296 doesn't show any satellite signal
Check that the date shown on the unit is correct. If not, choose autolocate and allow about 10 minutes for the unit to find satellites. If this works, then the internal lithium ion battery is defective.
Jun 02, 2010 | Garmin GPSMAP 295 GPS Receiver
It wont track satellites
Have you tried to reset it? Refer to your owners manual to do so if you haven't already.
Sep 30, 2009 | Garmin Nuvi 660 GPS Receiver
Won't acquire satellites
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} make sure you are in view of clear sky, large buildings, trees and even clouds will make it harder to track satellites.
May 19, 2009 | Garmin eTrex Venture Cx GPS Receiver
Not tracking
Reset the unit by clearing the memory. Hold the RIGHT ARROW key and press the POWER BUTTON, while holdingthe RIGHT ARROW key until the DELETE MEMORY screen appears. Select YES and press ENTER. Then procede to initialize the GPS. Leave it outdoors for an hour or so to acquire satelite feed.
Apr 20, 2009 | Magellan GPS 310 GPS Receiver
Garmin GPSMAP 492 GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
