Question about Pioneer DEH-P750MP CD Player
Pioneer deh-p750 locking
I was trying to fix the clock by stupidly pressing all the buttons on the display and i somehow managed to lock the radio. the only function that still works is the volume control. how do i go about unlocking the radio or did i just mess up the radio all together?
  • 363 Answers
Try pressing the reset button. It is usually in a little recessed hole on the front panel.
Posted on Sep 22, 2007
SOURCE:
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
Cannot shut the alarm function off all together.
Disable the alarm permanently 1. Press CANCEL button. 2. The WAKE indicator will be flashing. 3. Press WAKE MODE button within 3 sec- onds to deactivate the alarm function per- manently.
Mar 23, 2009 | GE 7-4837 Clock Radio
Can't set clock on stereo
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
Feb 10, 2009 | Pioneer Car Audio & Video
Military Time
Press the "function" button for a couple of seconds. The display will indicate 12hrs or 24hrs.
Use the minute or hour to change the setting for 12hrs and you'll have normal time again.
I hope this helps!
Feb 02, 2009 | Digital Products International Clok Smooth...
Complicated GE clock radio/CD player
To set the time:
Hit the SET Wake/Time Button closest to the CD player until the clock face appears in the bottom left hand of the display.
Use the TRACK Rev Search Fwd Arrows to adjust the time.
Rev will decrease by minutes and Fwd will increase by minutes.
Hope this helps.
Jan 10, 2008 | Audio Players & Recorders
Pioneer DEH 225 car radio instructio booklet
Actually, there a re a bunch of hits when you Google it.
For further assistance please consult your user manual.
Here are some other answers from around the web:
Hold down the source button till the unit switches off. Press thefunction button until it says clock. Use the tuner/volume controls tochange the time. Left/right switches between hour and minute. Up/downchanges the actual numbers.The website I'm including has all the old manuals on it if this doesnot work for you. Problem is, you may not know your model # so willhave to click through the links till you see a pic of one that lookslike yours. Hope this helps. I'm stoked that my clock is finally right!
turn the radio OFF with the car ON
then its easy to set the clock.
Most folks try to figure it out with the radio on
and it cant be done with the radio on,
Turn it off. Hold down "func" or "function" until something happens.
Then press the arrow keys still something else happens. When you're done, press "func" or "function" till nothing happens. Turn it on.
Dec 03, 2007 | Pioneer DEH-225 CD Changer
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Nov 07, 2007 | Pioneer KEH-P2030 Cassette Player
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
Pioneer DEH-P750MP CD Player Logo
652 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
