Will the MkII wheel drive work with the older black model? The control head and compass seem to be fine.. but the wheel does not move.
SOURCE: Raymarine St 4000 Wheel Drive
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
SOURCE: MKII E12093 Wheel Drive
Try to make new brackets for adapting to the screw holes on the rim ATTENTION the screws should NOT
go deeper in the rims as the original ones as they will interfeer with the internal parts and damage will result.
