Keystone kstap14a i have a keystone portable ac kstap14a I need to know the the size of the circle of the air outlet pipe
SOURCE: i need parts for everstar portable air conditioner
I have lost the exaust tube and the attachment that hooks up to the back of the unit to the tube. Where can I buy these parts?
Posted on Jul 19, 2009
  • 358 Answers
SOURCE: no power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Posted on Oct 25, 2009
motor1258
  • 6674 Answers
SOURCE: air cond & electrical outlet in 1999 sprinter by keystone 33 ft
One of your breakers in your main panel should be for either one of those. Simply test receptacle for power as you try flipping each breaker off and on, until you find the right one. Quite often a high amperage draw item like electric frying pan, or hotplate plugged into the one by the kitchen area is the culprit. If they smell, or appear burnt or scorched, they should be changed, as well as the entire circuit tested for proper size wiring, as well as rated receptacle to handle big power( amperage draw). Extension cords will also cause same problem. Make sure if you have to use an extension cord, that is a heavier gauge wire, approved for that use, and is as short as possible. I'm assuming your AC is plugged in to a receptacle, and not on roof?
Posted on Apr 23, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: Water clogged in the outlet pipe
Hello
This is the condensate drain line which drains humid water the a/c coil collects.
To clean you can try compressed air,blow through the pipe.Or take pipe apart and flush it out.
Have the unit off when doing this,also clean the collection pan out of debri.
Posted on May 12, 2010
Testimonial: "Thanks for the suggestion and the problem is resolved"
wiccan8house
  • 49 Answers
SOURCE: I have a Challenge AF10000E portable air conditioning unit with a pipe that needs replacing but I have no idea how to find out what size it is or where to get it from. Any ideas?
Here is a link to a manual I uploaded for ya. It does show some pics, dimensions and local by country tel. numbers and e-mail addys to order from -- good luck and I hope it helps you out -- wicc --
http://www.mediafire.com/view/?uhmf4qec57e1zsq
Posted on Aug 16, 2012
Is Portable AC worth the buy ?
split system is better option. more expensive but more dependable.
Sep 08, 2015 | Heating & Cooling
Where is the air compressor dryer located on a 1999 mercury mystique
I assume you mean the ac compressor dryer. It is located on the large low pressure suction pipe between the ac compressor and the firewall of the vehicle. It is about the size of a tall beer can and will have the large pipe going in one side and out the other.
Jun 06, 2014 | 2002 Pontiac Sunfire
Dont know how to hook up the drain pipe
The drain pipe in what? If we are talking about a sink, they sell multi size kits at lowes, home depot and any other hardware store. You need to know the size of the outlet from the sink and the size of the drain pipe you are connecting to.
Jun 07, 2012 | Dehumidifiers
Goldstar GP120CE portable air conditioner with the E3 error
Sounds like a clogged condenser pipe which is common for portable Ac . It is usually due to the unit sitting low and collect more pollens an particles at floor level. A pipe cleaner tends to do the trick. Also insects tend to harvest inside the drain pipe
Jul 15, 2011 | Heating & Cooling
We are installing a kelvinator ksv70hra split system air conditioner. What size pipes does the electrician need to install?
If the installation is not done by an experienced AC technican who does not know the size of the piping , I would not recommend you to proceed further as you might end up with a faulty installation. Please get this work done by a person who knows the subject or else the pipe connections and fittings may not be good enough to prevent leak of the gas thereby reducing yourr efficiency and reduce cooling.
There is more to this than just fitting the pipes and I advice you follow them wisely.
Nov 03, 2010 | Heating & Cooling
Connecting the compressor to a tank
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Jul 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
My vent is too short on my amcor model ALTL 12000E portable ac
Try to extend the pipe using a pvc pipe or, some sort of pipe.use alluminum tape that you can get at your local hardwhare store to seal the crack in the pipe that you use to extend..
May 27, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Air cond & electrical outlet in 1999 sprinter by keystone 33 ft
Apr 23, 2010 | Heating & Cooling
My new EC12 has never run, only hums.
try an outlet closer to the electric panel I have had the outlet wire size to small and far from panel and unit only hums let me know if this helps
Feb 23, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
