The error is SD. it means Suds. you use too much soap or the wrong kind. Must be HE. Remove top and find the pressure switch. Its white with a clear hose going to it. Unplug the hose and blow through it. This will clear suds from the line and you should hear bubbling in the tub. Re install hose and top. Run machine EMPTY with about a quarter cup of bleach and a little soap to rinse out tub and pump. Do this on a WHITE cycle. After this, it should be fine.
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
