Question about Garden
Remove spindle dissasembly of mower deck new holland 9828540 cant get apart
  • 37 Answers
SOURCE: Which way do the mower blades mount, on a Craftsman DT4000, 19HP Mower 42" deck?
Hi, make sure to put your blade curve end up. another word facing the motor
Posted on Nov 23, 2008
  • 376 Answers
SOURCE: How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Posted on Jun 15, 2009
wadembly
  • 513 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
  • 138 Answers
SOURCE: remove pulley on mower deck spindle
These are generally held on with just one large nut, I recommend you use a impact wrench otherwise it mau prove difficult ( you wont be able to hold the spindle tight enough) and certainly you will need a impact wrench to reassemble the spindle
Posted on Aug 22, 2009
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
New holland troubleshooting
Check the blade spindles one could be installed improperly. You can also install washers under bolts in spindle to get the adjustment you need.
Oct 01, 2017 | Garden
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How can you tell if the spindle belt is bad 1018 2000
If it only viberates when the mower is engaged then that is a clue.
But with the motor OFF, Look under the mower deck and check for bent or broken blades, Wiggle them up and down. If they wiggle too much then it could be a spindle bearing. A replacement is usually sold as a unit (Lowes carries them). Also check the general shape of the pulleys as well as the belts while you are at it. The belts tend to fray away like a old rope, or sometimes they will just break. If you do have to replace a spindle and you have a belt that is questionable then it is easyest to replace them all at once so you only have to drop the deck and tear it apart once because chances are you would have to remove the belt to replace the spindle anyway.
Sep 03, 2012 | Cub Cadet Street Sign- tractor lawn riding...
How to replace the spindle on a 48 inch mower deck
OK, Now I see your question under a different post. You are going to have to pull the deck out from under the spindle housing and spindle and replace them. They usually come as an assembly. after removing teh deck you should see the spindle housing retaining bolts to remove. Make sure you pull the blade off that spindle before you try removing it.
Oct 02, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Have 54 inch Craftsman mower deck that I am rebuilding - how do I remove the spindle from the Mandrel housing? Appears to be stuck but will spin.
Depends on how old the deck is. Some of the older spindles and mandrels were not made to came apart. The newer ones you can put the nut on the top threade to protect the threads and a couple of taps it should come out. If you have a model number you can got to sears web site aa they will have an exploded view. http://www.searspartsdirect.com/partsdirect/index.action
Mar 21, 2010 | Craftsman Garden
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
