Question about Fisher Price Flutterbye Dreams Swing
Replacement part need to find the sound and lights and movement of the bird, everything else works expect the piece
I just got a radford exchange purr-fect moments kitten cuckoo clock and the clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird sounds unit of th
There are several companies that sell that movement , just google clock movements and they have a chart with spec to match yours. I have replaced several in my time, its pretty easy
Jan 05, 2015 | Watches
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
Birds won't chirp on the hour on audobon society bird clock
If the clock is more than a few years old, it may be that the switch movement inside has gone out, or maybe the sound mechanism has gone out. You'd have to find a clock repair shop that would consider working on it. Search clock repair in your general area with whatever search engine you prefer.
Aug 09, 2013 | Home
Our bird clock has started running fast, gaining about 17 minutes each day. Any idea how to fix this?
No fix, other than replacing the time movement, which is a switch movement that can be purchased at several different clock part supply stores, catalogs, or websites.
Jul 14, 2013 | Audubon Society Audubon Singing Bird Clock
I have a 1988 ford t bird i bought the wiring kit and installed the after-market stereo and everything works expect the sound. and i ve tried other stereos and double checked the wiring and still no audio.
Check under the passenger's seat for a factory amp. If the blue wire on the aftermarket head unit (accessory/antenna) supply isn't hooked into the power line for the factory amp. You'll get nada. It's usually a bump in the carpet if it's not visible. Look for a spare wire in the dash that originally went to it.
Mar 15, 2010 | Car Audio & Video
Fisher Price Flutterbye Dreams Swing Logo
44 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
