Question about Daewoo Dwc-F0520rle Air Conditioners
Refrigerant replacement What do I need to buy to make my air conditioner work colder?
What kind of freon does this air use and where do you replace it?
You can not buy refrigerant without a licence
& the unit is sealed at the factory
There are ways to work on it,but you need
a week or two of A/C training to do it yourself
& some equipment you wouldn't have a reason
to go out & buy
Jul 09, 2011 | Haier Mechanical Air Conditioner HWF05XC7
My Airconditioner has ice forming and no cooling. can u suggest what the problem cud be?
Most likely a slow refrigerant leak. When the refrigerant is low, it actually gets colder and causes freezing in the coil. Another possibility is the coil is dirty, not allowing enough air flow through the coil. You didn't indicate if this is a room air conditioner or one attached to your furnace.In either case the coil should be cleaned first. Then if it is still freezing, you will need to have the leak repaired and refrigerant (freon) added to proper level.Normally the coil is not below freezing, but when the pressure drops too low it gets colder and then the condensate that normally drips off the coil freezes.
Oct 30, 2010 | Home
Room temp stays at 76 and will not get any colder even though unit seems to operate and compressor sounds like it turns on and fan blows and water drains . it is set to 60. room is about 300 sq ft
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
May 06, 2010 | Maytag M6P09S2ACOM Air Conditioner
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
When i turn ac on air blows hot. the fan is
sounds to me u need to have it recharrged
Oct 03, 2009 | 2004 Infiniti G35 Sport Coupe
LG 10,000 btu air conditioner
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
May 24, 2009 | LG Electronic Window Air Conditioner
Jenn Air JCD2389GTW Refrigerator problem
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Daewoo Dwc-F0520rle Air Conditioners Logo
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Dan Webster
Dan Webster
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
