Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
My printer is displaying "transfer roller Jam"how do i fix that
My printer is displaying "transfer rollar jam"
5 Suggested Answers
SOURCE: media jam transfer roller
Hello pp-helps,
This is very interesting. I do have the very SAME problem with my Xerox 6120 printer. I've been looking for the fuser roller all over without any sucess. The new fuser unit costs approximately the same as a new printer. I'm frustated at this time. I want to ask you the following: Are the mechanical components from the 2430 exactly the same as the 6120 as far as the fuser unit goes? if I find a roller replacement for the 2430 will it fit my 6120? do you have a p/n by any chance or know where can I get it?
I really really appreciate your help.
Regards,
Frank
Posted on Feb 18, 2008
SOURCE: Paper jam at transfer roller with no paper jammed
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
Posted on Jul 30, 2009
SOURCE: Paper jam
I same problem.. I hadn't used my one i months. tried printing and would only feed the paper in and make folded paper inside.
I fixed it by the damp cloth on the feeder roller. Not the bottom roller but the main one in the middle. I had to roll the roller abit. when I was rolling it it had fluff come through from the main roller that touches the drum. So roll the middle roller with your fingers and wipe.. keep doing it as it's rolling the the larger main one. will take a while until you get all the dust and fluff out!
Posted on Nov 05, 2009
SOURCE: printer paper comes out but does not have full
right side dose not print
Posted on Feb 14, 2011
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
My Samsung CLP-315 Laser Printer will print about a half page and then jam...everytime!
does the jam came out to the exit and stuck there or it jam in the printer or before the pickup?
if it got jam at the exit. the exit sensor is faulty it got to replace.
if it got jam in the printer. the transfer belt or fuser is faulty. both got to replace
if it got jam before pickup. pickup roller got to replace.
May 09, 2010 | Samsung CLP 315 Laser Printer
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Media jam, transfer roller
Replace the offending transfer roller.
Dec 20, 2009 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
