Question about Hardware & Accessories
How to operate Fuda Timer
I dont know how to operate this timer. Can anybody tell me how to work it?- Set a time on and off
  • 112 Answers
SOURCE: pool timer not working
http://intermatic.com/Default.asp?action=div&did=5
here is the link to intermatic, usually u take the pieces they give u and hold them up against the wheel and tighten the screw, at whatever time u wish for it to come on or go off, sometimes the trippers are different, this is just a generic answer, if its electronic its different. different brands are different.
have a good day
Posted on Jan 13, 2009
jyackle5
  • 8197 Answers
SOURCE: intermatic timer T101
This link should help you set timer.
http://www.intermatic.com/images/instruction_sheets/T101.pdf
Good Luck and Please Rate FixYa!
Posted on Feb 27, 2009
gotgeek2
  • 565 Answers
SOURCE: Timer doesn't come on after being set. Operates landscape lights
Check your circuit breaker that feeds the timer circuit in your main electric panel. It may have tripped. Sometimes when a breaker trips it's hard to tell visually, so turn the breaker off, then back on.
Also, the circuit that feeds the timer may be on the load side of a GFCI receptacle. Look for one that has tripped. Sometimes they are found in obscure places.
Posted on May 03, 2009
  • 864 Answers
SOURCE: I just bought a house with the Night Sentry EJ351
Here are the instructions: http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
You will have to pick the times you want the lights to go on and off.
Posted on Oct 29, 2009
SOURCE: I do not have operating
Instructions for DT300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
Posted on Oct 12, 2010
Testimonial: "Thanks, The user instructions for my Intermatic 7-day Digital Timer ( Model DT300 Series) is just what I needed"
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
Dx4500 ge dryer
Maybe the knob is broken and slipping on timer shaft. If not, replace timer.
Sep 10, 2017 | Dryers
I have a powerbar with 8 outlets 4 always on 4 controled by a digital timer with 6 buttons, Top row Day, Hour, Min. Bottom row Clk, Mode, Prg. When i set the timers my lights dont shut off or correlate to...
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
2) Check that battery is operable,
Move selector switch to ON position.
Check that each program has ON and OFF times set.
Check that each ON time has same days of operation as OFF time.
To delete programs, hold down MODE button and press Prog button.
Check outlet has correct polarity using circuit analyzer.
Try power strip on different outlet.
Check load rating of timer matches type of load being controlled.
This timer might not work for CFL inductive loads, try with ordinary light bulb.
Dec 28, 2012 | Globe Electric Hardware & Accessories
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
I have the 59017 Mechanical. I set the pins and turned on in timer mode. It comes on at specified time, goes off after specified time, but then does not come on again the next night.
I don't have repair for defective timer:
If Load and Line wires are reversed, that could explain problem. Reverse timer red and timer black wires. Symptom of this problem: the clock dial stops rotating after tripper pin.
Troubleshoot run-through:
1) Use fingers and manually rotate timer dial several times and watch if Load turns ON-and-OFF
This will tell you if load is operational, and pins are set correctly.
2) Set slide switch to Timer.
3) Make sure timer is wired correctly. This timer needs neutral wire to operate clock motor. Open following link to see illustration and read about wiring. Line and load wires must be correct.
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
4) Check that wire nuts are attached very tight and there are no loose wires.
Additional resource:
http://waterheatertimer.org/How-to-set-timers.html
Aug 21, 2011 | Woods Mechanical Inwall Timer 59017
I bought a weekly segment timer at argos and i dont know how it works
Timer is not clearly identified.
Open following link to see images and read general operation of segment timers.
Also open following link to help identify timer.
Add a comment and say what timer is same-similar to your timer for possible additional help, and/or what you did to solve problem.
Upvote the help.
Jun 03, 2011 | RTO Westek Weekly Segment Timer, White
Instructions on how to set termatic Time All D111
Open following link to identify D111 timer:
http://www.tesvacances.com/products/intermatic+time+all.aspx
Intermatic no longer shows that manual:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It appears as though you push down the trippers and rotate around until tripper is set at on-off times of your choosing. The trippers could also be removable, but I cannot tell.
There is a black and orange tripper but I do not know which is ON and which is OFF. You will have to experiment, or words on-off might be printed on tripper.
Clock motor located inside timer rotates dial as time passes, and trippers move lever that turns load on-off.
Manually rotate timer dial clockwise until current time lines up with a mark.
I cannot see current time mark, but there should be a mark that shows where dial is rotated to set current time.
There is probably also an override switch on side of timer. You can experiment which position switch should be set to.
If free instructions above are not perfect, then do not hesitate to add a comment and include photo of your timer, so I can see the product more clearly. Also say if you have both trippers, and if dial rotates as time passes that would indicate if timer is operable, and take photo of timer switch so expert can see clearly since expert is not at your home with hands on the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 24, 2011 | Intermatic INC ST01AC DIGITAL IN WALL...
Can't set timer
You posted under Grasslin in-wall mechanical timer.
Instructions for this timer are nearly identical to GE
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
First, the timer has to be wired correctly, so review wiring instructions shown on link above.
Next, the pins have to be set, so read instructions and look at image of pins shown on link above.
Last, the timer switch has to me set. I believe timer switch is moved all the way right for timer program to operate.
To check operation, manually rotate dial clockwise to watch lights turn on-off.
This will tell you exactly how to set pins and switch.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins trip a lever that opens and closes switch to your lights.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
Hardware & Accessories Logo
49 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
