Question about Candy Refrigerators
D77C15RAW5 Fridge overheating
Subzero fridge door left open. Has a new compressor just recently. Is there a reset button on the compressor to get it going again
The compressor has probably overheated. Leave the fridge unplugged for a few hours until it cools down. If you keep trying to use it, the compressor will fail again. They have a self resetting thermal cutout but these will fail if the compressor keeps overheating.
Sep 17, 2017 | Refrigerators
Beko fridge freezer. The interior light still comes on but both the fridge and freezer compartments aren't getting as cold as should (probably about only 20%)
hi there. well if its a standard fridge it could be 1- the stat 2-lack of refrigerant 3-or motor.difficult to check without a visual but if your condenser is nice and warm and the motor is not overheating then it could be the stat.either change it or turn off fridge bypass the stat wire and try.it will over freeze.(keep safety in mind first) if frost free then again condenser warm ,compressor not overhated then likely to b your defrost timer.(normally hiden near compressor at rear/good luck Ali
Aug 26, 2012 | Refrigerators
Fridge seems to attempt to start working then stalls lights are all on
Sounds like it is overheating the condeser fan motor. Take the plastic cover off below the front doors and carefully vaccuum it out. This might fix the problem if it hasn't been too damaged from overheating. Also make sure the fridge is an inch away from back wall as most are designed to have air circulate behind as well.
Jan 28, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge overheating but ice forming on back inside of fridge but water forming at front
My fridge has a very hot front frame which can be felt when the doors are open. Ice is forming on one of the drawers making it hard to open.Its a whirlpool Model Number 6G25DCXHSOO.
My location is Raby in sydney NSW.
Aug 07, 2010 | Refrigerators
The freezer and refrig are not cold everything thawed...
There could be a few things that may keep a fridge from cooling. I'll give some you the most basic ones.
Check temp dials (fridge and freezer) not set too warm.
Bad freezer fan motor.
Bad timer.
Burned, stuck or obstructed condenser cooling motor. (the one underneath fridge)
Dirty or obstructed condenser.
Bad fridge door seals.
Refrigerant leak.
Bad thermic switch
Compressor overheating or damaged.
Good Luck
Mar 07, 2010 | Refrigerators
Have maytag fridge about 5yrs old and is triggering the safety switch to go off every 5-6hrs , the freezer is ok the fridge is not cooling, what is the problem
Most likely it is short cycling because the start components or condenser fan are defective. This causes the compressor to run for a few minutes and stop because of overheating. The overheating is tripping the breaker. The cycle will not change until the issue with compressor or fan is resolved. To continue to allow it to run like this risk permanent compressor failure. Thanks, Sea Breeze
Feb 20, 2010 | Refrigerators
My Matsui under counter fridge smells of old milk/veg really badly despite cleaning out thoroughly including catch tray at back and downpipe. It is only 1 year old - any advice gratefully received
Can you pull out the fridge and check that the plastic power cable has not been pressed against the compressor at the rear/bottom of the fridge?
Usually, overheated plastic cable smells like rotten veg!
Nov 17, 2009 | Refrigerators
THE FRIDGE IS COOLING
could be ice build up around the fridge fan.
Sep 13, 2009 | Samsung RS2630SH Side by Side Refrigerator
Does your fridge still work?
It still runs like a charm.
The fan was the problem.
I replaced it and there have been no other problems.
Aug 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
Overheating
the inreasion of heat is normal if you recently add food to froze.Let it work for some hours without open it and check it again
Nov 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
90 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
