Question about Kenmore Dehumidifiers
Kenmore model 580.54351800 cuts off after a minute
Does not collect water, will not cut back on by itself but will run if the humidity control is rotated down and back up
Illeagle
  • 525 Answers
SOURCE: Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Posted on Jun 02, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
  • 340 Answers
SOURCE: Moisture not collected
low on freon is the compressor running?
Posted on Jun 18, 2009
  • 3 Answers
SOURCE: runs but does not collect water
It is possible that the cooling fins are not working due to insufficient coolant or the compressor system is faulty. Basically the fan pulls air across a cooling fin . Moisture from the air then condensates and falls into the pan as water. The air is then heated before it exits into the surroundings. The fact that there is no water collecting suggests that the cooling stage is not working. I see from other posts that there is a fuse somewhere. Maybe this fuse is blown and is associated with the cooling compressor..hope this helps
Posted on Aug 01, 2009
SOURCE: unit runs but no water collect
I unscrew the cover were's the air is ****'s inside and I just clean with water pressure.I beleive I have to do this every six month.The problem was;no more water collect,less air came out and the unit was very hot.Only clean the filter is not enough!!
Posted on Aug 25, 2009
Dehumidifier
when ice forms on an evaporator unit (coil) there is an indication of internal problems with the unit. IT may occur if there is insufficient air flow ( dirty or fan speed to low ) but when this happens the thermostat just orders more gas through the tx valve and so more ice is formed then the thermostat reads it as too cold and so cuts the gas flow back by controlling the operation of the tx valve
Water from a dehumidifier will depend on the atmosphere humidity so the lower the humidity reading the less water collected
However I suggest that you have a technician check it out as the compressor start/run capacitor may be faulty and that is why the compressor is not getting hot as it may not be running properly
Jul 23, 2015 | Dehumidifiers
Dehumidifier lights up comes on will only run for a few minutes does not collect any water
You probably have it set for too high (moist) a setting, so it doesn't need to run long.
Slowly reduce setting to Drier settings to get it to run longer.
Sep 19, 2017 | Kenmore Dehumidifiers
The dehumidifier come on and shortly cut back off , and there be no water in the bucket
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 12, 2011 | Kenmore 54501 Dehumidifier
My humidifier stars and stops, start and stops. It runs for a minute then shuts off.
It sounds as if you may have the humidity extraction level set to high. Try lowering it you 35% and check the water collection bucket, to make sure it is installed properly
Hope this helped you.
Jun 25, 2011 | Kenmore 54701 Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
Of our three 54501 Kenmore dehumidifiers, none produced water after two - three weeks. They run but no humidity is drawn out of the air.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. I find it uncanny, that all 3 units are not collecting any water. So, it may simply be the case, that the humidity level on each unit is improperly set.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filters on a regular basis, not is the time to do so. And while your at it, clean the cooling coils too.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 30 to 40 minutes and check the water collection bucket. If there's water in it, it's working as it should.
Hope this helped you to solve the problem. Please let me know.
May 03, 2011 | Kenmore 54501 Dehumidifier
The dehumidifier cuts off when it is set on 70% as soon as the compressor cuts on. i can leave it on lo and it runs.
If you're setting the humidity level on 70 % , that means you want to leave the relative humidity in the house at 70%. That's why the dehumidifier is cutting off. Your house is already at 70% humidity or higher. If you want to remove humidity, set the level lower. If your trying to make it cooler in the house or remove a lot of moisture, set it a 35 to 45%.
Hope this helped solve your problem.
Apr 16, 2011 | Kenmore Dehumidifiers
Dehumidifier runs but extracts no water at all. room is 65degrees & humidity is 75%. no frost on coil & no moisture either. kenmore model no. 580.54501.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 15, 2011 | Kenmore Dehumidifiers
I have a Model 25350650000 Kenmore Dehumidifier. Everything works--motor, fan, lights, won't extract humidity from air
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 22, 2010 | Kenmore Dehumidifiers
Dehumidifiers Logo
23 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
