Question about HEWLETT-PACKARD T790 InkJet Plotter Printer
T790: PDF files in wront format to print
I have a T790 hp postscript printer that wont print pdf files from my tower. I get an error on the printer display saying wrong format.
Why is my HP Designjet z5400 only processing a PDF but will not print it without an error message coming up?
First of all, can your so called pdf open in Adobe Acrobat Reader, if not, then you need to first convert your JPG into a PDF. You need a program to do this. But if you can open it in Reader, then you need to print it from there. Try one of these solutions.
Jul 03, 2015 | HP Designjet Z5400 PostScript Inkjet Large...
How to fix postcript for hp 1005 mfp printer
Here's the manual.
An encapsulated PostScript (EPS) file does not print with the correct fonts. Cause Solution This problem occurs with some programs. ? Try downloading the fonts that are contained in the EPS file to the device before printing. ? Send the file in ASCII format instead of binary encoding.
http://h10032.www1.hp.com/ctg/Manual/c00682960.pdf
May 18, 2015 | HP LaserJet M1005 MFP Printer
My HP Designjet T790 report "Error 21.2.:13, restart, if problem persists call support" i restarted but still can't print. Can you help me? Thanks
This is a service station error. One of the more common causes I have come across is a piece of paper or foreign object jammed in the service station. It is located on the right hand side of the carriage. Unplug the plotter. Plug it in and the minute that you hear the print head move, unplug the power. Then open the window, move the head out of the way and look for a foreign object stuck in the service station.
May 15, 2015 | HP Designjet T790 44-In Postscript...
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
When printing large powerpoint presentations half way through it will give a pcl xl error missingdata readimage
too much data or not enough memory in your printer to support the job.
Also possibly corrupted data in your powerpoint doc.
if you are using PCL version of the driver, download and setup the PS (PostScript) driver from HP.
There are conflicts with printing PDF/Powerpoint docs using PCL driver.
let us know if this helps. Another thing you can try if possible, convert the Powerpoint into a PDF file and then try printing, but select "Print as Image" in the Advanced section of the print options.
Feb 03, 2010 | HP Color LaserJet 4600n Printer
Pdf file too large: 1-2 pages about 1 MG.
Try and print the document 1 page at a time, upgrade the memory in the printer if you can, and most importantly; make sure that this is not a false error because the PDF requires postscript fonts to be installed you don't have installed on your printer. You can do this as follows.
Their are 3 standards for postscript, go to the manufacturers website and download the newest version of the postscript driver, not PCL. Many printers go nuts if running on an installed PCL driver and asked to print a PDF. If all else fails, this typically gives a lot of false errors.
Nov 08, 2009 | Brother MFC-8860DN All-In-One Laser...
Problems printing pdf files with an hp officejet pro 8500
You can try installing the PostScript driver rather than the default PCL driver for the printer. You may also have a faulty USB cable which is causing data errors when printing complex jobs such as PDFs.
Jul 08, 2009 | HP Office Equipment & Supplies
I am trying to print to adobe to convert to a pdf file. I am receiving an error stating Prodcut name: distiller Warning: Script-cannot be embedded beacuse of font file error. Error: undefined; offending...
You probably have Adobe reader which will allow you to read an Adobe document but not write a pdf file. For that you have to buy Adobe Acrobat. There are, however, free packages that will convert a file into pdf format. Try googling for "convert a file into pdf" or something similar.
Nov 24, 2008 | Computers & Internet
HP Printer 1320 PCL XL error
hi,
I'd suggest downloading and installing the PS (PostScript) driver from HP here: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=410624&prodTypeId=18972&prodSeriesId=410622&swLang=8&taskId=135&swEnvOID=228
Then use the PS driver when you're printing .pdf files. Use your existing PCL driver when printing all other types.
i hope it would help you...
Oct 13, 2008 | HP LaserJet 1320 Printer
Postscript printing on hp laser jet 1020
Are you using a postscrip driver for this printer not pcl
Oct 27, 2007 | HP LaserJet 1020 Printer
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
