Question about Garden
Snapper sr140 The spark plug don't make a chispa
2 Suggested Answers
bukkuz350
  • 6 Answers
SOURCE: snapper mower 331416kue won't start
You can try buy a new spark plug and replace it with the old one.
I had the same problem!
You just have to keep pulling until it catches!
Or maybe it's the carburetor that needs to be replaced!
I had the same problem wih my scooter.
I just changed the carburetor and it worked fine :)
Posted on Sep 08, 2012
22' snapper walk behind mowewont start .cleaned spark plug and still wont start .swapped spark plugs from another mower that does work and the other mower starts with the snapper mower's spark plug .
You need several things for a running internal combustion engine:
  • Air
  • Spark (to start)
  • Fuel
  • Compression
  • Lubrication
  • Exhaust.
You've shown that you have a workable spark plug so far. Going from the above, consider as well
  • Fuel. Bad / old / contaminated fuel. Clogged fuel filter. If it's a motor that needs gas/oil mix, does your gas have the right oil mix?
  • Air: Dirty, clogged air filter or air inlet.
  • Spark. Is any electricity making it to that proven-workable spark plug?
  • Compression. For this one, the most likely problem (other than a toss-the-engine thing like a broken piston) would be if the spark plug is not tightened into the mount hole, allowing the air to leak out rather than compress.
  • Exhaust. Most lawn mowers will have a spark arrestor on the exhaust to make sure you don't set a dry yard on fire with your exhaust. It's often overlooked in diagnosing two-stroke engines. Make sure it's not clogged or blocked.
  • Lubrication. Is there oil of the right type, and up to a proper level on the dipstick. No oil equals way too much friction in the engine.
Good Luck!
DH
Apr 25, 2016 | Snapper Garden
No hay chispa en las bujias
Hi, Tirso and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose, check for spark leakage in the dark.
6. Faulty ignition coil, pick up coil, trigger coil or CDI box testing needs to be checked with an ohmmeter at 70 degrees Fahrenheit
7. Faulty safety switches clutch, kickstand, neutral, off/on etc.
8. Faulty ignition switch.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic no spark no start
YZF600R Forums View topic No Spark desperate can get around Did break it
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Mar 02, 2014 | Yamaha YZF 600 R thunder cat Motorcycles
How to remove spark plug wire from spark plug?
The spark plug wires on your bike connect the same way as on most cars.
Pull the insulated boot directly away from the spark plug. Just make sure you pull on the insulated boot, and not on the wire.
Jul 03, 2013 | Yamaha XJ 650 Motorcycles
Where are the components located on a 1994 E320 Mercedes Sedan?
don\'t understand: cranks fast enough (battery low??) or crank at all??. Need more detail(s);if it cranks at all but slow,you won\'t get a spark;don\'t touch the end of the spark plug wire \'cause it\'d make your butt pucker if/when you get spark!!! honestly.
Jan 29, 2013 | 1994 Mercedes-Benz E-Class
Snapper mower 331416kue won't start
Sep 08, 2012 | Garden
No spark on W1-185V
I seem to go through this every year my lawnmower. What I do is drain the fuel tank and fill with fresh fuel. Then I replace the spark plug with a new one and it starts up right away. Otherwise I'd take it to a small engine repair shop for a tune up.
May 20, 2012 | Snapper Garden
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Snapper riding mower carburetor floods engine it wont stay running
The carb. is working. Get a carb. kit and in it. They don't cost much.
Mar 30, 2012 | Snapper Garden
I put new plugs in mygsx600f and it wont start
Obviously your no2&3 cylinders are dead.Take a new spark plug and stick it in the no2 plug cap.Touch the spark plug's tread to a bolt or nut on the engine and crank it.If you don't see spark on the spark's nose (which you most likely will), repeat procedure to no3 cylinder's spark plug cap.Both plugs are part of No 2 coil. The No1 coil feeds cylinders #1 & #4 cylinders.Find or borrow another pair, mostly all suzukis from that era, uses the same coils.If you see spark with the replacement, just means your one ignition coil is bad and you buy new oneIf you still don't see spark with the replacement coil, then the problem lies to your ECU.
Feb 07, 2012 | 1999 Suzuki GSX 600 F (Katana)
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
