Koolking model MPN1-08CRN1-BH9. Where can I get a manual?
That was such a good answer but the link no longer works. I'll see if I can find something else. Does anyone know if this unit has an adaptor/slider long enough to fit a patio door?
Posted on May 10, 2016
2 Suggested Answers
elitecgdwolf
  • 744 Answers
SOURCE: Where can I get an owners manual for this?
This is a link I found on Google, when you click on it, you will get a PDF to read or download. If this is the one you are looking for, as you did not mention the brand name. Good Luck
]MPG-08CRN1-BH9 Owners Manual(English).cdr - Home ...
www.homedepot.com/.../04e58fe2-bf7f-4c94-9867-a0...
The Home DepotBefore operating this product, please read the instructions carefully and save this manual for future use. Model: MPG-08CRN1-BH9. MPG-10CRN1-BH9 ... http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CD8QFjAA&url=http%3A%2F%2Fwww.homedepot.com%2Fcatalog%2Fpdfimages%2F04%2F04e58fe2-bf7f-4c94-9867-a0aae44fd179.pdf&ei=4-saVa-dHKndsATBuoKIDA&usg=AFQjCNFijFLs2Z-aQdWNf3QnRnnSf3Wp4g&sig2=VOqqXSTzs_m5A11RyJeQCA&bvm=bv.89744112,d.cWc&cad=rja
Posted on Mar 31, 2015
I have a touch point mpn-08crn1-bh9 ac unit.it work's fine but it is noisy.i can not find a reason.does the fan wheel get dirty and throw it out of balance.and if so how do i get to the fan blade
Of course it gets dirty but normally it gets dirty uniformly. If it's out of balance the unit would be shaking, is this the case? Getting to the wheel is a difficult task, even for a professional. Make very minor adjustments to the positioning of the unit in hopes to cure noise, I don't suggest opening up the machine or taking it off the wall.
Aug 18, 2017 | Heating & Cooling
KoolKing 3812-950 is producing unmanageable amount of water when in AC setting?
That means your machine is working great. Either turn it off or "manage" the water. How about using the drain tube !!??!!
Jul 09, 2017 | Heating & Cooling
I have a KoolKing 3812-972 heating question
Last month I had the exact same issue with my HVAC system blowing out more cold air than hot. I didn't know what to do and so I had a heating service come and look at it. They were able to fix it and I was told that the issue had been due to my always keeping it on blast and that made the unit break down a little. You may want to consider how often you try and heat your home. http://www.advancedheatingandcooling.com/HeatPumps.aspx
Jan 07, 2016 | Heating & Cooling
Model 3812-972 MPPD-14HRN1-BH9
air conditioners are in effect heat pumps
that is they pump the hot air in the room via a gas to the outside area
when that outside are is still inside the room then that hot air is just recirculated
so if you want to heat your room the system is reversed so that you need the hot air outside pumped back into the room
the hot air is provided by the condenser which is now the evaporator in the room as the roles have been reversed so you will have to put the unit in a door way or use the ducting hoses to go out a window
Nov 03, 2015 | Heating & Cooling
Mar 31, 2015 | Heating & Cooling
Why is the floor under koolking wet
If the drain is clogged or the ac is not slightly tilted towards the outside, the condensed water will leak inside instead of outside where it belongs.
Jul 17, 2014 | LG Heat cool Window Air Conditioner
Should both lines be insulated on midea ductless ac
s. Wherever the capillary tube is in the out door unit, then suction and liquid line should be insulated.
Jun 01, 2014 | Midea 10K BTU Portable AC - MPG-10CRN1-BH9
Heating & Cooling Logo
507 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
