Question about Hitachi RAS-09UH Air Conditioner
Hitachi ras 12u
Theres water dripping on the floor from my air conditionning, why is that?
  • 2692 Answers
SOURCE: Need a new remote for my Hitachi RAS-12UH Ductless Split
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Posted on Jan 08, 2009
  • 66 Answers
SOURCE: Hitachi RAS-10C2M. What size of air conditioner
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
Posted on Feb 23, 2010
SOURCE: I NEED A USER MANUAL FOR A HITACHI SPLIT SYSTEM
http://www.hitachiaircon.com/argws/listDOCS.do?pageName=Technical+Manuals&range_id=1&page=PAGE&button=Submit&categoryID=-1&action=getListTechManuals&d-49653-p=14
Posted on Mar 23, 2010
angelo_mlc
  • 1035 Answers
SOURCE: We have a Hitachi wall
Hi. Here's the link where you can purchase a remote control. Please click here.
Posted on Sep 02, 2010
dcramer531
  • 1654 Answers
SOURCE: My hitachi air conditioning ras
According to the codes you gave me, it is telling me that it is sensing that it does not have enough of a gas charge to run. It is getting this code from the sensors attached to the cooling coils. The alarm code is as stated below.
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
So either you have a faulty sensor or the unit sprung a leak while it was being unhooked and hooked back up. In either case you will need a licensed repair person to do the work as it will involve releasing and filling the coolant charge from the unit. It is unlawfull for anyone unlicensed to do this work. That law is from the federal government.
Posted on Mar 29, 2011
I have a "Hitachi split type air conditioner model RAS- 3098U", and its started leaking today from the right side. I didn't install it and I can't figure out how to remove the front cover to l
water is coming from evaporator drain pan most likely. lots of humidity right now and 1st thing your ac is going to do is remove this from air. most likely cause would be condensation line clogged or if you have condensate pump, then it also could be cause. to remove cover usually you have to remove air filters look for any screws and possibly front louvers pull down. this usually does not give you access to drain pan. unit usually needs to be removed from wall plate and this might involve refrigerant lines being removed, and for that my friend you defiantly want a qualified professional.
Aug 13, 2012 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
The unit started dripping water and not sure how to get to the gutter tray without major problems. The water is not flowing out the outlet pipe to the outside like it should. Just want to make sure the...
u could do it another way without getting to the tray. Do u know where the condensate drain goes? if u do and you have a wet vac just vacuum that line and it should clear
Aug 17, 2011 | Hitachi RAS-09UH Air Conditioner
I need a service manual for Hitachi airconditoner model RAS-4HQE5
Hello, I have this manual but it is downloaded at a 3rd party site where I store my info. Go to the supplied link, follow the Hitachi file. Note - there are a few annoying pop ups, b ut be patient and you will get the file. http://www.mediafire.com/?mreiznz5mtz
May 13, 2010 | Hitachi RAS-09UH Air Conditioner
Feb 23, 2010 | Hitachi Heating & Cooling
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
Water leak
maybe theres a pin hole from rust in your fire wall. On my 1993 gran prix it had a pin hole and right by the pin hole in the fir wall there was a little lip in the metal and it would hold water for sometime.
Dec 16, 2008 | Mazda Protege Cars & Trucks
Hitachi RAS-09UH Air Conditioner Logo
154 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
