Question about Tappan TGFS_63 Gas Kitchen Range
Oven won't heat
My Tappan gas oven won't heat up. I don't hear the gas ignite, but I do see the little coil light up and I smell the gas. I'm not sure if it is supposed to have a pilot light or not.
  • 63 Answers
Try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Posted on Aug 29, 2007
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
The top burners all work fine. When I turn on the oven, there is no smell of gas, or anything. Any suggestions? the stove top burners are working well but the oven is not generating any heat although the...
IF THIS IS A NEW STOVE THERE IS A VALVE IF YOU PULL OUT THE LOWER DRAWER AND LOOK WITH A FLASH LIGHT YOU WILL SEE A VALVE AT THE REAR OF THE STOVEAT THE LOWER LEFT OF THE VALVE THERE IS A TINY LITTLE HANDLE WHICH OPENS THE GAS TO THE OVEN FLIP THE LITTLE LEVER SO IT IS IN THE OPEN POSSITION, THERE ARE NO MARKS SAYING OPEN OR CLOSED AND THE LEVER IS VERY HARD TO SEE
TRY THIS AND SEE IF THE OVEN STARTS WORKING
Aug 25, 2009 | Tappan TGF303BW Gas Range
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Oven will not heat up, I can not hear any gas or smell any when attempting to light the oven
If the pilot is lit in the oven and does not light, the thermocouple on the gas valve is bad. The entire gas valve must be replaced.
May 19, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Nov 22, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGFS_63 Gas Kitchen Range Logo
281 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
