Question about Kenmore 15864/15862 Top Load Washer
Kenmore 90 series manual 110 92591220 20922991
There is a smell from the wash machine. How do I remove the agitator to clean the filter. Kenmore model 110.20922991.
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
  • 262 Answers
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Posted on Jan 11, 2009
  • 1214 Answers
SOURCE: Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Posted on Feb 04, 2009
  • 1937 Answers
SOURCE: My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jan 12, 2010
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 90 Series Washing Machine. Does it have a filter that needs to be cleaned regularly. I owned a maytag previously. It had a center post that collected lint etc. that needed to be cleaned. I...
It's an auto-clean internal lint filter. Lint is trapped from water circulating through the filter during the wash cycle. During the drain cycle it's backwashed and the lint goes down the drain.
Feb 02, 2018 | Kenmore Washing Machines
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Washing machine not rensing well
there is a magic clean filter on bottom of basket. it has been removed from newer models because it builtup **** and never cleaned itself. need to remove agitator and basket to clean tub and remove plastic filter from bottom of basket. special tool required for basket
Mar 14, 2009 | Washing Machines
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Filter
most washing machines don't have a filter now , however read the owners manual to make sure if it has a filter
Jun 23, 2008 | Washing Machines
Kenmore 15864/15862 Top Load Washer Logo
295 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
