Whirpool washer s/n20072300402-010477011-01 will not spin door will not open
Washer will not spin nor will door open
5 Suggested Answers
  • 165 Answers
SOURCE: WHIRPOOL FRONT LOADER WASHER NOT SPINNING
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
f this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
Posted on Feb 20, 2009
  • 1294 Answers
SOURCE: The door on my front end Whirpool Duet Washer will not open?
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
For the door to unlock, press & hold 'end of cycle' for 3 seconds, power shd be on for this, try door after 2 minutes. Your machine may not open if there is water inside, so first drain.
Posted on Apr 05, 2009
  • 89 Answers
SOURCE: Our Whirpool duet washer will not spin, gives us
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Posted on Oct 09, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirpool duet washer is displaying F33 code.
The F33 error indicates a PUMP DRIVE SYSTEM ERROR and occurs when the connection between pump and the Central Control Unit (CCU) is lost.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit (CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
System Leak - Select 'cancel' twice to clear error code. Check for any cracks or holes in the washer tub or pressure switch hose. Replace if damaged.
Also
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Whirpool washer front end loader lock light is on. but i can open the door the wash is empty. unplugged replugged it and tested the GIF the plug its in had power too, other wise the light to the lock...
unplug the washer, remove the lower front panel, put your hand under the front panel and pull a little lever behind the door lock mechanism and pull the door open.
Feb 05, 2011 | Whirlpool Washing Machines
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Whirpool duet is making a clacking noise on the spin cycle.
Reach inside and see if there is any play to the inner/spin tub (up and down) . Tub may be seperating from mounting and spindle assembly.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool
I would say to worry about it , if its flooding your house , need to open washer front panel ,start a new wash cycle and take a look to see where the water is leaking from , sounds like a broken hose under the tub that connects to the DRAIN MOTOR PUMP , AND BETTER have it fix right away cause if its getting to the main motor it could damage it , hope it helps AJ
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
