Question about Tablets & eReaders
Android kasaco 7in tablet M752 wont go past loading screen
5 Suggested Answers
  • 3940 Answers
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Posted on Oct 25, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
My tablet pc is stuck on the start up screen an will not go any further what should I do
Posted on Mar 02, 2013
How do i do a factory reset on m752
To factory reset: 1. Turn off the tablet 2. Press and hold volume down and power simultaneouly. Hold it for 30 seconds until an Android logo will appear on screen then let go. 3. Scroll down by pressing Volume down and Volume up to select any from the selection. 4. Select Wipe Data/Reset and select wipe data again and wait till it`s done. 5. Go back to the menu and select reboot to restart the system. Once the tablet has been restarted it will all be back to default values.
Bets Wishes
check here:
http://office.manualsonline.com/support/other/tablet/where-is-the-reset-button-on-a-kocaso-m752-tablet-5408896#comments
- Don
Oct 31, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
Froze on black screen that says android have tried holding down power and volume still froze
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Feb 23, 2014 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
My Kocaso M752 says it's connected to our wifi but it hasn't asked for the password.
The programmed password is stored on the android tablet, from last time.
Until you say "forget" site
Feb 09, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
How to unlock passcode pattern on my android tablet kocaso m752
switch off your tab
hold up button
keep pressing power button multiple times
it'll show you hard reset setting
if not
then hold up and down simultaneously and keep pressing power button
reply me when you succeded
Feb 02, 2014 | Kocaso M752 Dual Camera Android 4.0 ICS...
No puedo entrar en recovery en mi tablet m752 y no enciende se queda en la pantalla de inicio existe alguna solucion?
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Feb 02, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
Kocaso m752
My keyboards disappeared now it won't come back.m752 4.0.4
Jan 14, 2014 | Tablets & eReaders
Screen is unreadable after charging battery on M752
take the tablet back to where you got it and get a new one if it has been to long get ahold of tech support for solutions and if there solutions don't solve the issue and you have owned it less than a year they will more than ikely send you a new one in return for the old one.
Nov 11, 2013 | Kocaso M752 Dual Camera Android 4.0 ICS...
Tablets & eReaders Logo
142 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
