Question about Brother Office Equipment & Supplies
Diagnostic code 1
I try to give print,but its showing error the code is Diagnostic-code(-1)
Cogz
  • 1326 Answers
SOURCE: Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Posted on Jul 22, 2008
SOURCE: 1997 sunfire Diagnostic Code PO742 ( torque converter circuit stuck on ) how to repair?
TCC silonoid.. torque converter control... seems simple but you gotta drop the front subframe to get the side panel cover to but it in....
Posted on Aug 25, 2008
mcalkins3
  • 123 Answers
SOURCE: diagnostic code p0135
What engine is in this vehicle? I assume the avalon would be a 3.0L or similar V6 engine. Bank 1 sensor one indicates one of the primary O 2 sensor controlling a/f ratio. Sensor one bank one would be the sensor located in the Front manifold, closest to the engine. Hope this solves your issue. I would first check the conector at this sensor for corrison before buying a new sensor.
Posted on Sep 29, 2008
mspcrepair
  • 169 Answers
SOURCE: hp psc 1210 not working in vista - but diagnostic utility shows all ok - and prints test page
Here is the full-write up on the HP PSC1210. Read through this thoroughly to ensure that you follow all the steps to make it work in Vista, since there is no Vista native driver.
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
PABLOCSA
  • 1124 Answers
SOURCE: prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
Black cartridge problem device documentation. HP Officejet 4500
This type of HP 901 ink cartridge error ("Refer to Device Documentation", etc.) condition is likely an internal micro-electronic failure inside the HP 901 (or 901XL) black ink cartridge. These failures typically occur due to natural degradation of internal micro-electronics over time and can occur with brand new ink cartridges.
To confirm root cause and check the internal electrical condition of both black and color ink cartridges, please execute the 'Tap 41' cartridge's electrical diagnostic test below (refer to procedure B).
CAUTION: Be advised, the use of remanufactured ink cartridges is considered somewhat unreliable since the cartridges are already on their 3rd life when purchased new (off the internet or at select retailer stores). As well, the use of compatible/clone cartridges (i.e. sold thru the internet from China) are known to be problematic and may cause printer errors.
NOTE 1: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
DIAGNOSTIC CHECKS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to 2nd video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=620
a. Load Letter/A4-size paper into paper feed tray.
b. If any lights are blinking, first press Cancel to attempt to clear.
c. Press the * and # keys simultaneously.
d. Enter 124 at keypad. The 'Underware' menu should be displayed.
e. Use the arrow keys to navigate to the System Menu. Select Ok.
f. Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Printer screen should display "code = 0".
g. Use the arrow keys to enter "code = 41" (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern prints.
--- Providing the HP 901 (or 901XL) color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health - the printer will attempt to print the diagnostic test print). A good HP 901 color cartridge should display 1248 good nozzles, while a good HP 901/901XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the diagnostic test print: http://inkjet411.com/?page_id=620
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For more diagnostic tests and error bypass procedures, please visit the Inkjet411 support center: http://www.inkjet411.com
Hopefully this helps....
Sep 12, 2013 | HP Officejet 4500 All-in-One -...
Town Car 2004 wont start on first try
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 22, 2012 | 2004 Lincoln Town Car
Code P0171
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 21, 2012 | 2004 Lincoln Navigator
What is P0174 and P0171 to lean on bank 1 and 2
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 17, 2012 | 2002 Mitsubishi Montero
OBD II code PO100
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 04, 2012 | 1997 Nissan Pickup
Ligth
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 01, 2012 | 2001 Chevrolet Tracker
Obd2 code p0171
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Jan 28, 2012 | 2004 Ford Focus
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Jul 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
