Question about Prestige Aps95bt2 Elvat5c Replacement Transmitter
Valet/Bypass Switch Location 1995 Honda Accord
I have tried everything to find the valet switch on a used 1995 Honda Accord that I purchased. It came with this alarm system installed, however the one remote that came with it is almost broken, so I purchased a matching one. But now can't find the valet switch in order to program it. I've read that some have the push button on the LED, however the blinking LED was installed where the power sunroof switch usually goes (my car is not equipped with a sunroof so it was just a blank space) with a tiny hole drilled to show the LED through it. It doesn't look like you can push the LED. Any help here would be appreciated. Thanks!
  • 22,326 Answers
Wow no idea at all ,is this the original factory alarm or a add on one
Posted on Jul 17, 2013
Testimonial: "I have no idea...my guess is that it's an added one, since it doesn't look the most professional the way it's installed (LED drilled through the empty sunroof switch place)."
Valet switch
lost the operators guide, well you are in luck , its online
honda's and jeeps are the 2 best cars that way. lots of DATA. free.
here it is ,
http://justgivemethedamnmanual.com/honda/honda-accord-owners-manuals/
now put in a mem, stick and never need to ask again. be impowered
Jan 24, 2014 | 2001 Honda Accord
Prestige electronic alarm installed
SEE THE diagrams attached. God bless you7a1b523b-85a3-41dc-98b7-63a3c3bc8ad2.gifcc747f95-169f-45b3-b656-517dc47283d6.jpg
Jul 17, 2013 | 1995 Honda Accord
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
Accidentally reversed the battery cables on my 98 honda accord 4cyl. 2.3l. I already replaced the main 100 amp fuse, replaced the main relay, replaced battery , and had alternator tested and its good. it...
If your car came with the Prestige Alarm unit, there is a possibility that the alarm box got deprogrammed or burned, and left the anti-theft activated. Use the Valet Switch to deactivate the alarm permanently, and see if the car starts. For some reason unknown to me, it takes a couple of cycles of crank/ take the ignition switch off, crank again for the Valet Switch to work. In my 98 Accord, this micro-switch is installed in the left front kicker panel, but there is no guarantee that it will be in the same place in you accord, since it is a dealer installed option
Jun 12, 2011 | 1998 Honda Accord
Where is the Alarm Valet Switch on a 1997 Honda Accord LX. The alarm was installed prior to purchase of the new car in 1997, but came with a separate manual. The Manual has no info about who designed, or...
it SHOULD be installed on the left kick panel where your left foot would hit if you were driving it. if not pull that panel off and look there the installer might have had a lazy day or left his drill at home but its there somewhere
Sep 30, 2009 | 1997 Honda Accord
Where is the valet switch for honda accord 2002 lx?
Does the vehicle have an aftermarket alarm system? Is the valet switch for this what you are looking for? If so, it depends entirely on who installed it as where they have put it, although it's usually under the dash on the driver’s side. Some alarms have different sequences that you have to go through to put the alarm into valet mode; it's not usually just a switch that you flick. Best to pop into an alarm or stereo installer and see if they can spot it for you, or if the car is immobilized, find out what sort of alarm it is and call an installer for the info on the valet procedure.
Thank You for contacting Fixya.com
Aug 03, 2009 | 2008 Honda Accord
I can't find the valet switch on my 2001 Honda Accord
Look under dash above brake pedal......it should be mounted there. Or in some rare cases can be taped into wire harness .....not on lower edge of dash.
Jun 23, 2009 | 2001 Honda Accord
Where is the valet switch on a 1999 honda accord?
Your Grey key is the valet key.
The Grey key will not open the glove compartment nor the trunk, BUT you have to lock the back shelf and remote trunk release handle in the car, and the glove compartment with the black key first.
Apr 27, 2009 | 1999 Honda Accord
Need to find the valet switch for 2008 honda accord
Hi,welcome to fix ya. the valet switch is in the glove box
Mar 14, 2009 | 2008 Honda Accord
Prestige Aps95bt2 Elvat5c Replacement Transmitter Logo
194 people viewed this question
Top Prestige Electronics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Prestige Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
