Question about GPS
Sokkia ERROR E022,WHAT ROBLEM?
In Sokkia CX 101 Total Station Error E097 comes ....What is it means and how to solve that ???
CX series
www.sokkia.com.tw/download/??/CX_series_E-copy.pdf
Jan 1, 2012 - CX-105. CX-107. Compact X-ellence Station. CLASS 2 Laser Product ... Except where stated, "CX" means CX-101/102/103/105/107. • The CX ..... Ignoring this indication and making an operation error .... Make sure that moisture or dust particles do not come in contact with the inside .... detergent solution.
Mar 21, 2017 | Computers & Internet
The lcd displayed E190 error. i want to know the problem
The E 190 message means there is an error in the horizontal encoder. You need to contact the Sokkia service.
Apr 06, 2016 | Sokkia Set 610 Series Total Station Topcon...
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
What is meant E024 error code of SET550X SOKKIA total station?
Hi Aung,
E024 is for F4 cal level error.
what this means is that one of the frequencies used in your distance measurement needs adjustment. This adjustment can normally be done as part of your annual service.
Not having it serviced for a long time is often the reason why these types of error will occur....
rgds, Paul
Jun 09, 2014 | Sokkia Set550x Total Station, Two Years...
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
Km-3035 (kyocera) send email from scanner key, eveything seems to go fine, but no one gets emails, going into history of sending I find error E022. manual is no good, it give no codes. searched google, no...
The E022 error indicates -
The mail contained an e-mail address that the SMTP server can not find.
Check to make sure that the destination e-mail address was entered correctly.
The link below will take you to the manufactures web page where you can download the Scan System Operation Guide (Function Edition which list the error codes.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=11796&rid=14242
If you continue to have a problem you can go to www.gfbm.net for more assistance, also they have some Kyocera setup and troubleshooting information.
I hope this is helpful,
Shawn
Feb 24, 2011 | Kyocera Mita KM-3035 All-In-One Laser...
How to download the files from sokkia total station 1030 r
To Down load pls let me know com set up (Sokkia 1030R instrument)
BAud rate ,parity & Bits
May 18, 2010 | GPS
Error code E022 on a 3225 model printer/scanner
This error is telling you the SMTP server does not understand the email address typed in by the user
Check that the destination address has been correctly entered
Aug 28, 2008 | Kyocera Office Equipment & Supplies
GPS Logo
65 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
