Question about Sanyo Katana SCP-6600 Cellular Phone
Katana- Submerged in water for less than 2 minutes
It was submerged in a hot tub for less than two minutes, i immediatly took the battery out and dried it in the sun. It turns on now and vibrates and everything but the keypad will not work and i also can not recieve incoming calls. What do i do?
  • 21 Answers
Dang, that is not good the keypad is waterdamaged for good. Take it into a store and have them run a diagnostic on the phone itself. As far as the incoming calls you should still be able to receive those... that is weird actually I would call in for that. Hope that helps :)
Posted on Nov 22, 2007
SOURCE:
Cell phone salt-water damage
Put it in a bowl of rice and stick it in the hotpress!
Doubt it will work since it was submerged for so long but worth the try!
Owen.
Jan 11, 2013 | Nokia 1661 Cell Phone
What's the difference between in-line and submerged water pumps?
There are many differences between the two of them in the way they run but the main difference is the in-line water pumps run outside of water and stay dry the whole process and submerged water pumps run underwater usually in the sump of your filter.
Aug 09, 2012 | Fish
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
What can I do to turn on my digital camera after it was submerged in water?
First of all you should get (or have gotten) the battery out as soon as possible. You could try shaking excess water out of it. You should then put it in rice to draw all the moisture out of the camera. This may take a couple of days, maybe exchange with more dry rice after first day. When you are relatively sure all moisture is gone try reinstalling the battery. I will guess that you will only have a 20% chance of it ever working again.
Dec 21, 2011 | Canon Cameras
My samsung sph m350 took a swim in the hot tub...got the back dry, but there is still water in the lcd part how do i take it apart to dry it? phone is not working. thanks.
i personally wouldn't risk further damage by taking it apart to try and dry it off. one trick i use and it may seem silly but does work is to soak it in uncooked rice for a few hours the rice will pull out the water after some time and can help the device work. If the device had been submerged or soaked for any substantial amount of time with the battery in it, it may be a lost cause fyi.
Apr 04, 2011 | Cell Phones
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Feb 23, 2010 | Flotec 1/4 Horsepower Sink Pump System
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
My wife's LG 8550 got wet and now won't power on
If the phone was still on while it got submerged, then you may be out of luck. Had it been off when it was submerged, using the rice trick might have worked. I would try removing the battery, and drying it out some more, but the damage may have already been done. Sorry!
Mar 15, 2009 | Verizon Communications LG Chocolate Cell...
My phone was submerged in water and I took out the sim card and the battery and towl dried it. The next moring I opened up and it would come on, so i charged it and when I came home later around 4 the...
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Feb 28, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Dropped the i580 in a glass of water
Put the whole phone in a container of rice and let it dry out completely.
Jun 01, 2008 | Motorola Mobility i580 Cellular Phone
Sanyo Katana SCP-6600 Cellular Phone Logo
69 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Steve Allison
Steve Allison
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
