Epson tw3500 purple line + start up issues
Epson tw3500 came up with a thick purple line that run across the bottom of the screen. This first occurred when the projector bulb was changed for the first time, the bulb was changed once more but the problem remained. After a while the projector stopped turning on after first attempt but that has escalated to only turning on after about 10 attempts.
INTERLOGIC
  • 326 Answers
SOURCE: brand new projector- has lines across the screen scrolling
check the lighting coil
Posted on Jan 17, 2009
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
vortash
  • 431 Answers
SOURCE: When connected to any computer and attempt to play any video,it has a bunch of horizontal lines resembling a barcode running horizontally across image.
Hi my name is Vortash the bars you are seeing are the result of a capacitor or diode failure in the projector possibly in the power supply , they are usually referred to as ac hum bars .. this is where a circuit that should be running on pure dc voltage is being tainted by ac seepage from another part of the machine .. its also possible with the heat generated in these units it is just bad solder or dry joints ,,, best get an engineer to check it though as ot may damage the bulb and I would bet money on a repair being cheaper than a replacement bulb hoe this helps regards Vortash
Posted on May 17, 2009
projdoc
  • 2237 Answers
SOURCE: Projector attempts to light the lamp, but to no avail
the ballast is gone and needs replacing. unfortunately, infocus has no parts for that model.
Posted on Nov 05, 2009
  • 269 Answers
SOURCE: thick purple line scrolling up from bottom of screen continually
if it is a uniform pulsating line, then it is the main board or engine. if it is a fuzzy line it is the light tunnel
Posted on May 11, 2010
A small horizontal line going across the bottom.Now a horizontal shadow appeared above the line.Each day a new shadow appears & lighter then the rest.Now a thick box of silver/purple lines at bottom.
Seems like back-light fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 12, 2016 | Televison & Video
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Samsung TV thick black line running across the bottom.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Thick purple line scrolling up from bottom of screen continually
Apr 26, 2010 | InFocus IN72 Multimedia Projector
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
Purple color band at top of TV screen
If the problem is visible on all inputs (DVD, sat, etc.) you have a bad optical block. That model has a two year warrnty on the block but you'll have to pay labor to get it replaced
Oct 16, 2008 | Sony KDF46E2000 46" Projection HDTV
27 people viewed this question
jasbo
jasbo
